Guest Rhino
Us WA ppl are in the middle of organising a trip down to the Motorplex in the next couple of weeks and I was looking for advice on launch techniques for a R32 GTR.
I have dialed up 5,000rpm on the street and it bogs, whereas 6500rpm is pretty good in my opinion. What is a good launch rpm for a proper strip?
I want the GTR's first run session(not to mention mine) to be a good, fast and safe outing. I hope redline launches aren't going to to be the order of the day as I'd prefer not to rape my car to get a good time when a sensible approach will net a good result.
Fingers crossed for 12's.
Cheers,
Ryan.
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/
  • 2 months later...
From memory there was a .30sec reduction in ET by increasing launch rpm from 5,500 - 7,000rpm, terminal speed went up by 4 - 6kph as well.
7,000 launches give a fair whack of wheel spin and spinning in 2nd was also common, depending on whether I got the shift to 2nd right.
I did 4 13.0xx sec passes in a row with my old clutch which was a factory item about half worn with a dodgy flywheel face. The MC day the Perth people had last Sunday was my first chance to flog the new clutch and it has proven to be pretty bloody good for a clutch that isn't any harsher or harder to drive than the factory unit.
The day at the drags was good, but no 12sec. passes just lost of 13.0's!! That was with the old clutch slipping a bit and 50L of fuel on board. Next time 1/4 tank of fuel and I'll have a 12sec timeslip in my pocket.
Cheers.
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-69798
heres ulas results
1st run...
5 grand dump, as i usually do on the street.
60 foot - 2.024
ET - 13.129
MPH - 106.52
2nd run...
i thought that i was wheelspinning too much off the line so i took off at a 4 grand dump (wrong thing to do!)
reaction time
60 foot - 2.310
ET - 13.903
MPH - 104.61
3rd run...
on this run, we all decided that i just launch at a 7 grand dump. the car rocketed!
60 foot - 1.881
ET - 12.776
MPH - 107.41
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-69803
ok cool... have u had it tuned?
ula had his tuned at the dyno day we had not long ago... cant remember the mods he has but its nothing outrageous but i remember he was getting 210rwkw or around 275rwhp.
hes running the stock GTR rims and not sure on the tyres
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-69818
heya Rhino... my rims are standard with crappy 225 rubber on them. clutch has also been upgraded but mines only a cat back exhaust. our theory was that you have to get the rear wheels to spin so the computer picks it up and then moves power to the front wheels which gets you the better take off, hence the 7000 dump. i wasn't game to try the rev limiter dump (only on gran turismo 3 hehe :) ) i know that my times wouldnt improve unless i had better and wider rubber. hope you get a good time!
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-69834
Hey Guys,
Use the rev limiter. Thats what it's there for!
The best way to get consistent launching is to take off the same
every time.Hold the revs up around 5-6000 then when the first
amber comes on flatten it and watch for the green.The trick is not
to sidestep the clutch(which will create problems-trust me) but to
ease it off with a little bit of slip.You must hold the car on the line
with the handbrake(or a line locker)to take up the slack in the
driveline.I have smashed std driveshafts, diff output shafts,3 gearboxes, & recently an HKS driveshaft!!! It just takes practice.
You shouldn't start breaking things until you pass 300rwkw, so if
your GTR is stock or mild give it heaps.Biggest problem is tyres.
Old, hard road tyres will not hook up.Borrow some sticky ones,
do big burnouts, experiment with tyre pressures,etc.
Drag racing GTRs is great fun.
I took out my R34 which only has exhaust & apexi power FC and
ran 12.1 @ 115mph! Don't over rev it. If your car is not making power over 7000rpm change gears earlier - it will run faster.
Have fun.
P.S. I have a mate over there with a GTR torana.Runs mid nines!!!
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-69851
Yep,
I do drive my R34 that hard.It's the only way to get it off the line
properly without bogging.Check out the Jap guys.You always hear
them popping on the rev limiter before they launch.:burnout:
Go hard or Go home.With the R33(OS 3 Litre engine) I sit on
9000 rpm for at least 5 seconds before launch to build up the boost.Any 4WD with a small capacity turbo engine needs revs to
launch hard.They don't have much bottom end torque, so if you
come off the clutch too early you bog the engine, lose torque, &
lose time. It is much easier to launch a V8 because they have so much torque.My old HJ holden ute (350 chev) used to launch at
4-4500rpm, run a 1.4 60ft, & 10.1 @ 133 mph.Also most V8s use
a trans & torque convertor which multiplies the torque & literally
slingshots the car off the line.
We are doing it the hard way with Hi-tech, multivalve,turbocharged,small capacity engines - & using solid clutches & manual gearboxs plus hard street suspension/steet tyres.It is much harder than old school drag racing, but it is a challenge, and it is great fun.Dropping the clutch at full revs, changing 4 or 5 gears,keeping the engine on boost,and all the while trying to keep the car off the wall is very entertaining!
There is no doubt that V8s are king of competition drag racing,
but you try and drive a 10sec V8 car on the street reliably.
This is where Hi-tech comes into it's own.They handle well, go like stink,behave on the street in traffic,& have all the creature comforts.Go skylines!!!
:uh-huh:
https://www.sau.com.au/forums/topic/2079-gtr-strip-launch/#findComment-71271
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
