Munro - you wouldn't happen to own that silver R33 GTR with TD-06's that was in zoom ages ago ???
Nissaner don't change when it hits the rev limiter otherwise it will bog.... keep your foot in to till you get traction and reach the speed you normal change gears at..
Fatz is a sore losser :shake:
No. That TD06 car belongs to Doug Dinan.I have driven it though.
9500rpm 1st,2nd,&3rd & it flies.Should of seen the grandma on the sidewalk jumping over the fence to avoid the blur!Probably
thought it was a jet landing or something!The TD06s dont come on boost till around 6000rpm so you have to rev the hell out of it to get a useful power band.His car was the inspiration for mine.
Although I seem to have lost the plot somewhere along the way!
My car is on page 26 of HPI no.24 & page 60 of Zoom no. 54.
Due to the 3 litre capacity & smallish? 2835R turbos it comes on
much earlier(around 4500rpm) & the push in the back is awesome.
Doug's car has just had a fresh engine build by Adelaide Engine
Developments so I'll have to watch out next time I run into him
on the street with my R33!!! HaHa:uh-huh:
Doug is a helicopter pilot so he is really good at low flying.:)
Another mate, Kier Wilson, has also had an OS 3 litre engine fitted
to his R32 GTR so Adelaide certainly has some sick GTRs around the place.Looking forward to summer.It will be good to get these
3 GTRs together for some WRX hunting.:shake:
Munro.
Kier cars is the one that ran 10.6 ??
2835R's DAM thats some tasty turbos ;) 4500rpm seem pretty dam good for thoes turbo's to come on !! what does she rev to ??
I don't have any of thoes mag issues :) don't suppose you could post a picture ??? i would love to see more of your beast !!
When you and Doug have a little run in please for the love of god film it :P nothing better then watching 2 tuff GTR's fight it out :uh-huh:
Guys I did a few launches in the GTR last nite.
I tried 6500 and it seemed oookay... nothing spectacular. I still felt it bogged a bit. Then 5000 it was very slow off the mark. I also found that with the 6500 launch the car got traction pretty quick and then I tapped out in 1st gear before I realised it and shifted to 2nd.... probably lost me half a second...
My car is standard with exhaust and boost restrictor removed... when we talk about redline lauches are we talking 7000, 8000 or in between???
Also how much abuse can the clutch take before it dies??
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
    • Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
