ring bridgestone as paul said, i was asking about 225/40R17 adrenalin potenza re001's the other day, and rockingham store had them in stock.
they quoted me $300/tyre for that size
RE01-R and RE001 are 2 different tyres.
i'm tring to find someone who can bring or does bring in the RE01-R, or if anyone know of any special on atm for the RE001,
(calling Bridgestone won't help for the RE01-R as i have talk to a bridgestone dealer and they have called around for me and found out that bridgestone does not supply the RE01-R as part of their an official product line in australia)
As i wont pay $300 for the RE001, when i can get import the RE01-R for similar price and they are a better tyre
Edited by [Michael]
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3680790
yes i do realised they are 2 different tyres, however in your title it says "Re01-r Supplier ?, or Adrenalin Potenza RE001 ?" so i was simply telling you a supplier for the Adrenalin Potenza RE001 like you asked.
if you were after the RE01R instead, why did you ask about the other one? :down:
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3680952
im interested, so what place stocks them?
u had them on at drift prac the other night right? they value for money?
end up going with the RE001 as i got them for $270 each inc fitting (235/45/17). If i had the extra cash i would have for the RE01-R
BTC stock the RE01-R
BTC Bentley
21 Sevenoaks St,
Bentley WA 6102
Phone : (08) 9458 4586
Fax : (08) 9451 7664
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3697974
    • Yes, the problem is the supply chain hasn't standardized on metric which makes it more expensive to source metric hardware. They're all mail order at this point. Fastenal is cheap but you can't exactly rock up to a fulfillment warehouse as a random D2C. Paying 13 USD for 3 nuts doesn't really make sense. McMaster-Carr and similar companies are all in a similar sort of boat. If you like gambling on mystery hardware Amazon is cheap too but you're going to be buying 25 of whatever screw you need. So Lowes/Home Depot ends up being the way to go if you really only need small quantities of hardware for odd jobs like trying to rebuild a power steering pump that calls for an m6x1.0 screw to pop out the flow control valve.
    • What size bolts did you use to reattach the cam cover baffles? Thinking it will need to be M3-M4
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
