  mitchy_ said:
ring bridgestone as paul said, i was asking about 225/40R17 adrenalin potenza re001's the other day, and rockingham store had them in stock.
they quoted me $300/tyre for that size
RE01-R and RE001 are 2 different tyres.
i'm tring to find someone who can bring or does bring in the RE01-R, or if anyone know of any special on atm for the RE001,
(calling Bridgestone won't help for the RE01-R as i have talk to a bridgestone dealer and they have called around for me and found out that bridgestone does not supply the RE01-R as part of their an official product line in australia)
As i wont pay $300 for the RE001, when i can get import the RE01-R for similar price and they are a better tyre
Edited by [Michael]
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3680790
yes i do realised they are 2 different tyres, however in your title it says "Re01-r Supplier ?, or Adrenalin Potenza RE001 ?" so i was simply telling you a supplier for the Adrenalin Potenza RE001 like you asked.
if you were after the RE01R instead, why did you ask about the other one? :down:
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3680952
  [Michael] said:
thanks
if anyone is interested i found place in perth which stocks RE01-R
i got quote $345 for 235/45/R17
im interested, so what place stocks them?
u had them on at drift prac the other night right? they value for money?
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3697964
end up going with the RE001 as i got them for $270 each inc fitting (235/45/17). If i had the extra cash i would have for the RE01-R
BTC stock the RE01-R
BTC Bentley
21 Sevenoaks St,
Bentley WA 6102
Phone : (08) 9458 4586
Fax : (08) 9451 7664
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3697974
  sidewayssam said:
ok k, how where the RE001's? much of a diffrence?
the RE001 are great, very grippy tyre i was surprised about how good they were. From what i have read and been told the RE01-R is even better but is a very soft compound tyre so it will wear alot faster.
https://www.sau.com.au/forums/topic/207913-re01-r-supplier/#findComment-3698810
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
