  • Replies 128
Yep oblivion, i checked before buying that everything is in stock. So the turbo should be here probably monday i'm guessing (maybe tomorrow if im lucky).
I asked HPIAB and to my suprise they have a "real" GT3071R on the shelf ready to go... and yes it is "a 700177-23 core which allows an off the shelf .63 4 bolt" - to quote morrie. This matches up to the garret specs on http://www.turbobygarrett.com/turbobygarre...T30/GT3071R.htm so FINALLY i've bought it (and at a decent price).
Unfortunately, there's no place i know of in melbourne that does these at a decent price - not that i've looked all that hard as i've stuck mostly to online buying. An mate who actually works for Honeywell didn't give me a better price either. Getting them from America is cheap (especially with the current exchange rate) - but they take an absolute hammering during shipping (don't beleive anyone who says otherwise) so stick local!
what price are we talking about (PM me if u like)?
I got a pleasant surprise when i unwrapped my turbo. It is a genuine -23 cart :wave:
And unfortunately even with the garrett turbine housing and .5 A/R cover it still needs a spacer.
But the turbine housing is bollocksing massive! And it's only a .63. All i've dealt with for the last 2 years is my non gated .63 turbine housing and t28 sized ones. This thing is a monster!
edit: lol at the swear subsitution enabled on the forum :wave:
Edited by BHDave
The viewers at home would probably like some snaps of the ID tag and that 0.63 A/R GT30 IW turbine housing so they know one when they see one .
Cheers and thanks , A .
Apologies in advance for the quality of the pics. Low light and phone camera aren't a good combo. At least one of the 3 photos of the tag is partially legible....
Out of interest, does anyone know why garrett make the inlet smaller than a regular t3 size? As i have a spacer i'll be die grinding that to smooth the inlet into the turbo, but it just doesn't make sense to me.
oh yeah. manifold to turbo studs are 1.5 pitch where they screw into the manifold but 1.25 on the other end. just discovered that after buying new long 1.25 studs :thumbsup:
im not sure either BHDave, but i tired diegrinding the spacer and i was there for ages getting no where, i paid 20 bucks for a machinist shop to mill it out for me after i traced an outline of the real flange size onto it.
goddamnit! This was supposed to be easy! :thumbsup:
nah no problem putting it out there:
HPIAB: $1950 ($1750 for external gate)
CRD: $1920 ($1770 for the external wastegate)
APT: US$1449 + US$95 shipping + import duty + GST etc etc
FULL-RACE: US$1149 + all above (didn't reply to any emails).
Looked at ALOT of other places; most didn't have the "real" one, or didn't reply to my questions.
Like i said before, vary wary of overseas shipping of delicate items like a turbo - not only that, you have next to no protection if your stuff isn't right/ get ripped off etc etc.
Edited by -33-
BHDave I think the reason why the Nissan RB20/25 manifold flange is wider than GT30/35 turbine housings is because they are a split pulse design so probably more like a "Euro T4 twin scroll" housing flange pattern than single scroll T3 .
Brett Lloyd once told me that there is lots minor variation like this and another one is the larger T4 and T4 "International" which some call T45 .
Geoff Raicer (FullRace Geoff) had issues with some housings because they are large T4 twin scroll flange and stud holes but with T4 Euro twin inlets .
The problem seems to come from the fact that Garrett is not one company and different parts of it in different parts of the worlds made different things to suit themselves .
Once we start to mix n match different bits things like this are common .
Cheers A .
That actually makes sense when you look at the area of the outlet/inlet. If you allow for the center divider of the stock manifold it's be pretty close in effective area to the single scroll inlet of the new turbo.
An hour and a half, 1 grinding wheel and 4 beers later i managed to get the spacer flared out to match the gasket. It looks pretty good atm, i'll reassess when i'm sober :) Also did a trial fit, I need to reroute some wiring or i may have some issues when i hit the track and the housing gets warm. It's a pretty tight fit in an r32.
Picked it up today from the depot...
Its an authentic 3071R, code and compressor housing matches BHPDAVE's above (-5023)... but what's the exhaust housing??? Doesn't look the same!!! Its for ext. gate =(
Edited by -33-
haha nice work! yeah i moved my wiriong further up, then insulated with wrap. other then that tho it fits in there nicely!
definately. There's still more room around the turbo than i had with the old kit. It was also a novelty to be able to access 11 of the 12 manifold nuts with a socket from the top. It used to take me 2 hours of swearing and crawling under the car with an open ended spanner to get the old turbo and manifold on. this time it took me about half an hour. I still spent 2 hours reinstalling the bastard water hose that runs across the back of the head....
Intake pipe and hot pipe are just about sorted. just need to find a spot to fit the bov (stupid type R is too big to fit easily if you want it plumbed back). The front half of the front pipe is tacked up. Will be having a go with the wastegate pipe tonight before doing much more with it.
WELL, i just found out that AVO makes a 0.63 internally gated exhaust housing to suit the 3071, with an RB25 dump pattern... AND at the same price as a garret exhaust housing. I'm looking to put either the garret one (requires new dump) or the AVO one on my "real" 3071 (since i don't want the external gate).
Anyone had any experience, info on these??
it may or may not be similar to what i have, exceopt i doubt the AVO wont will cater for the full 60 mm wheel. I have a cropped 3071R with a GCG cast rear housing (OP6 copy) which meets up to rb25 dump and manifold. it is a 0.71 AR. i just dynoed it the other day with cams in it no and made 290 rwkw on 1.2 bar.
personally i think 0.63 is too small for a 25
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
