  • Replies 128
This creeping boost saga is a mind-bender, and I don’t know that there is a clear cut answer. The tendency to rise and fall regardless of whether running straight off the actuator or EBC gives a few clues, and yeah it is clearly a balancing act to get everything working together properly with this 0.63 A/R spec IW housing. Possibly a large diameter wastegate actuator can is part of the solution, as suggested? Given the actuator will have a limited range of travel, is there any evidence of flex/bend in the actuator mounting bracket? That might be a telltale of backpressure trying to force it further open.
Observed boost levels are falling back to the targeted level as rpm (and mass-flow of gases) rise. That could be due to skyrocketing turbine inlet pressure; or alternatively massive venting through the wastegate causing turbine speed to fall away.
If the backpressure rose out of proportion to boost pressure, then measured boost will drop because backpressure works against the boosted inlet charge. Monitoring turbine inlet pressure would tell virtually all you would need from a turbine efficiency / flow / wastegate capacity perspective. The HKS Pro S housing actually has a threaded hole right below the turbine inlet flange - just the ticket for screwing in a pressure fitting.
Tracking turbine speeds is achieveable with the kit now offered by Garrett, but IMO it’s a bit of overkill for a one-off use unless there are the $$ available. Still, it is great that the gear is available to data acquisition nutters at reasonable prices.
Getting to a solution without spending big $$ or investing/wasting lots of time, first thing I would do is look for bend/flex in that actuator bracket. Secondly, check for any evidence during dyno running, or your road testing, of knock? (presuming you've got a PFC and Datalogit access). A cluey tuner will have a good idea whether backpressure + scavenging issues are inhibiting the tune and inducing knock.
You could go on searching for the cause/s, but the key is whether it is boosting predictably and not just running away when you really want 100% reliability at the track. Apart from the fact that it is overboosting then dropping back, does it run the way you want it to? One thing is clear: sub 4000rpm the 3071 punches hard and really fills out total area under the curve.
After all that, if/when you have car down-time, the drilling/tapping operation into manifold or housing is quick and relatively easy. Use an NPT fitting and length of coiled bundy tube to dissipate heat, and a temporary pressure gauge will tell all.
Edited by Dale FZ1
At this stage i don't mind working around the midrange hump. It seems to be something i will be stuck with until i go either a larger housing or external gate, neither option i can really afford for now. Boost can be held under 1.4bar now so I'm happy about that atleast, even though it means running less than 1 bar at the bottom end. The gate blowing open is an issue that only a tighter actuator can resolve, the concern then is whether that will push the midrange creep up beyond the 1.3-4bar it sits at now.
It's not falling back to the set pressure, it is generally falling to about 1 bar, whether it's set at that or higher.
Sub 4k it is making a lot more power than the old setup. I did a bodgy overlay last night, as all my dynos are plotted on the same scale so very easy to trace, and 4k is about where the cross over occurs. I'm about 20-25rwkw down for the rest of the run, though on road it doesn't seem to lack anything. The peak AFM reading is also about .25V down on where it used to be. I would like to get atleast 10 more kw up top to make this whole exercise worthwhile.
So who has a supplier for actuators? GCG seem to be a bit limited in that field. And who can give me some advice on a pfc boost control kit and how well it will handle this issue/what sort of tunability is there? I read the faq, it seems to be very basic (you set a target boost, but still have to muck about with a duty to get it to hold it?). Anyone have some thoughts or experience?
  • 3 months later...
holy thread ressurection :(
rather then starting a new thread, ill stick it here.....
Still trying to decide what to get for an RB25. A real 3071r in .63 or .82 ??? IF anyone has a dyno graph of the .82 that they can post up, that would be awsome ! Seen the .63 earlier in this thread. When can i expect full boost in 2nd gear with .82 ?
Thanks.
Edited by KISIN
have a look in the dyno results thread near the end for skylinecouple's results.
He's also posted in one of the other 3071 threads floating around
Thanks champ, just had a look...still not helping me decide lol. I basicly just want to be 100% sure i can can crack 250rwkw without much problems at all and have room for more (porbably a safe-ish 270)... .63 or .82 ?
Thanks.
don't get a .63 internal gate housing. If you get ex gate .63 with a 44mm gate it will be an animal on an rb25. the .63 will just scrape in 270.
if you want to keep the stock manifold stick with a .82
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
