well im bookin my baby in for a major service and im not happy with the gearbox oil in it.. i had a heavy oil in it when i first bought it but as posted then it was crunchin when changing down into 4th and sometimes when going in to 4th on the way up if givin it some.. as im aware its the synchros however then i had a lighter oil put in to allow for the synchros to open quicker...
but ive been told to try one of those redline shock treatment's as many people have stated that they help fix that problem..
So after all that bs, my question is what a real good oil to use and or does that redline stuff work and which one.?
any help would be appreciated..
Cheers,
Corey
https://www.sau.com.au/forums/topic/207944-decent-oil-for-32gtr-box/
+ 3 for red line shockproof...
There are three types... heavy, light and superlight from memory...
I used the light one.. as mention above its the blue coloured one.
Expect to pay for it tho.. i think i paid 120 for 1 us gallon... or 3.8 litre in our terms.
yea it does
something about the particles going into the gears making it smoother..
not exactly sure on the technical info behind it
But it came high recommended from a trusted mechanic.
so i put it in, and it is as sweet as ever.
  • 3 weeks later...
motul gear competition or motul gear 300
redline schockproof is not ment to be used in gearboxes with synchros..it states it on their website too
Hi i used here in mi country dominicain republic a motul 75w90 syntheny for gear box mechany, but i have a questions how many liter used this:
-the gear box ( how many liter of oil used)
-rear diffs (how many liter of ATF used)
Please help me about that i need this information, the gear box is new and empty too, help me, beacuse tomorow mi mechany he gonna put this transmission.......mi car is a skyline gtr r33 year 1996....
Edited by godzukid_gtr33
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
