hey all,
just threw an emanage ultimate in the ol' r33 gtst, set the parameters and did a base map, but no injectors are firing. thing is, im using a r33gtr plugin harness, now is there any drop down resistors IN the harness that anyone knows about? im thinking this is the issue. either that or the ecu is fried.
any ideas are greatly appreciated!!!
and before i get abused, YES i know, its a damn e manage.... im playing ok haha
Cheers,
dan
https://www.sau.com.au/forums/topic/208018-new-ecu-injectors-not-firing/
did you do the wire swap that you have to do? if not, that will probably be your problem. also get rid of your base map. just reset it, set it up for rb25 airflow meter and leave it as that. don't make any map adjustments.
the gtr loom does work with the wire swap. that is what everyone with a gts-t is using.
