TRUST stainless steel dumps and stainless front-pipe taken R34 GTR V-spec (thought they were HKS until Ben/Racepace corrected me, thanks Ben!))
been on the car since purchased, 2 years now
excellent condition, no dents or damage, natural discoloration due to heat
$750 ono
fits R34 GTR, may fit other models
(pics below)...SOLD
OEM R34 GTR twin Garett turbos (x2)
75,000km
excellent condition, no shaft play, haven't missed a beat. maximum boost of 1 bar
$600 ono PRICE DROP...now $480ono
according to my knowledge, will fit R32/R33/R34 GTRs
(pics below)
All items located in Melbourne
Call/sms Shiraz Patel 0412 683 246 or email to [email protected]
Edited by BlueBeast
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
