Hey fellas,
I order 20 sets of 6000K HID kits!!
They are all Brand New in box (6000K HID kits to suit H1/H3/H7)
It comes with 12months warranty from the manufacturer----all kits will be inspected before delivery to ensure they are 100% working order.
They are $145 delivered
Also if more than 10 ppl order the HID kit everyone will get $5 rebate from the dealer!!
The name of the businesses supplying the kits for this group buy is Ganki JDM Garage
The end date will be 30/04/2008 firm!!
I will post some pic tomorrow when I install the H1 to my R33!!
Any enquiries please feel free to either pm me or reply here
Edited by cool_banana
Hey fellas,
Ooh! Ohh! what exactly is in the kit?
hey man..have u got a pic of the HID kit workin at night? and hows the difficulty of installation? whats in the package? are all the necessary stuff included? thanks
PM SENT
What brand are they. Could you post a pic of the complete kit. and all the spec's.
Also can you get a H3c fitment kit as both 32 GTR and GTS use the H3c style plugs. or would i have to mod plug's to h3 series.
very concerned about the h3c and h3 style..and is the kit hi lo beam?
I not too sure why cool_banana is so keen on PM contact rather than just posting in the public forum... but anyway!
I asked the same question (about the hi lo beam) via PM... they are just a single lo-beam. In his exact words: "normally we only put in low beam because it bright enough so no need to put the high beam only low beam is ok"
hey buddy intrested in the HID kit.. 6000k alot of blue? or 8000k even more blue?
6000k is close to sun light and 8000k more blue but the distance for the light is shorter than 6000k
As per the group buy rules, please update your first post to include the name of the businesses supplying the kits for this group buy, and a firm start and end date.
ok thanks
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
