You can keep the RB26 aac valve, but you have to change to the RB26 oil cooler set up. Also, the RB26 plenum will not clear the VVT solenoid on the side of the motor. It hits a coolant passage, so you either have to do non-vvt cams, or do some grinding/aluminium welding.
Throttle response is pretty cool though :cheers:
im just back from the workshop and we've got it fitting perfectly.
however as you said the vct solenoid & plug does hit the mani so it has to be cut and a piece of angle bar welded onto it. also one of the sensors needs to be moved to the underside of the mani. also the water outlet pipe (the bottom one) needs to be rotated anticlockwise (the hose still fits however).
you can use the rb25 aac, but it needs to be relocated - a bracket will be included in the kit (bolt onto the top 2 engine mount bolts)
clearance between the plenum and the brake booster/clutch cylinder and shockie tower is actually pretty good, id say more clearance than in a gtr
i'll get some pics tomorrow and upload them :thumbsup:
i'll get some pics tomorrow and upload them :cheers:
Noice work Ninja. Cant wait to see it. :thumbsup:
cool, would love to see pics :thumbsup:
i have just order my kit from japan so should be here within the week hopfully i can do the swap in a weekend if not i might just wait till a buy another daily
I'm pretty surprised you said there is more clearance. Mine is tight as a frogs butt.
Wait, you are putting this in a R33, huh? I've got a RB25 in my R32, so you must have a ton more room.
Just FYI there is a SAU Vic car (Red 32) in latest autosalon magazine using the RB26 setup on 25 head
Go see ben at race pace he has them, if its like his other work it will be impeccable.
Any word on 20DET Adaptation Shane? Or too hard basket?
farken whoops. forgot all about it.
it SHOULD be similar to the 25 setup, with a change of bolt location on the first plate.
where are you located? i'd ideally like to have the car on hand to make sure it all fits. i'll PM u my number so we can have a chat about it - i have a few ideas
QUOTE(dano4127 @ 28 Feb 2008, 12:17 PM)
Yeah thats my R32.
What do you need to know.
Im verry happy with it. It gives killer response and 40hp straight up.
Understand that Gready pleniums have stuff all responce and have no performace advantage untill about 450kw so there great for drag thats it.
Adz, what size huffer you using mate? All indications are the 20 won't pull enough air through so keen to know the performance on yours, especially at low boost, part throttle, low rpm. Good one BTW :)
Im running a RB25 with a GT3582 or GT3540 in the old language.
Wouldnt recomend the rb26 set up on a 20 head.
Car feels great at all rpm and runns about 15psi. It just feels like it wants to get up and boogy all the time.
any idea when the kit will be available to purchases?
as after exchanging emails with the Japaneses supplier, they said some parts need to be changed and welded :D which i'm not very keen on, Does your kit required anything similar or is it just a swap setup?
and will you be running an adopter to use the rb25 acc value or adopter to run the 26 acc value on the 25?
wish you were located in perth :D
Edited by [Michael]
atm im waiting on the admins on here to get back to me as i need trader status. That was over a week ago when i asked them.
if you want to retain your VCT, then there will be some welding required (look at the pics in post 66, near the vct solenoid)
no adapters need to be used for the aac :down:
no adapters need to be used for the aac :)
what are the benefits of retaining the VCT? and is it as simple as removing that section of the gtr plenuming and welding the gts-t part on?
"V-TEC just kicked in....YO!!" :)
Basically you get the cam and mapping responding to whatever computer you use to change the inlet timing relative to the engine RPM.
So on my race car, with no VCT but using GTS25t PFC I have the VCT set to over 10,000 RPM, so nothing changes at all.
I haven't looked hard enough to know about the welding.
interesting, where on the pfc h/c does it show the VCT setting, as i might have alook see at mine
You have to have datalogit and the software. You can't get to it in the hand controller.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
