Rb26 Inlet Manifold And Adaptation To Rb25 Heads .
what are the benefits of retaining the VCT? and is it as simple as removing that section of the gtr plenuming and welding the gts-t part on?
only benefit i see is cost. i.e it costs a fair amount to change to a solid lifter/cam setup. but then you have a huge selection of cams to chose from
i dont really want to go explaining exactly what needs to be done on the open forum, however purchasers will be told exactly what to do and whats needed
thanks for the reply :thumbsup:
i understand not wanting to make everything public :D
If my j-spec supplier doesn't work out i will be getting in contact with you for sure ;)
again thanks for all the helpfully reply :)
Edited by [Michael]
Wouldnt recomend the rb26 set up on a 20 head.
Why? Not enough airflow?
Shane and I have spoken a bit about making one for the 20..... Im hoping this isnt an exercise in money wasting....
Edited by R31 drift pig
That's right, not enough airflow for it to make decent response and stumbling on throttle openings. The velocities of the air are what is important. But for the cost, just setup a custom 6tb intake.
Call Wayne at Meridian Motorsport in Melbourne. He can either organise the setup or put you in touch with someone who can.
why is there not enough air flow? cause the 20 heads have smaller ports?
Been lurking for a bit, but now I am finally in the position to get some wk done to the car. I am very interested in the ITB conversion for my (RB25) RB30DET. Is there any (signiciant) difference in ITB designs throughout the RB26 year models that I should be looking for? I have done a search, but came up empty handed.
I already have the Greddy intake with the Q45 TB, but on my '77 280Z that manifold angles out too far and for the most part hits the fender. The GTR manifold would pretty much perfectly line up with the openings in the rad support to the FMIC. Plus the extra throttle response wouldn't suck either...
through i give an update on my situation.
After searching long and hard i finally found a brand new Blitz Kit :P (found on yahoo auction) price was too good to pass up :(
my gtr plenum comes this week and hopfully the blitz kit will be here within 5-6days. i put some pics up of the kit once it arrive
I have done the sums many times for many people, no matter how I work it it ALWAYS works out cheaper to sell the RB25 cylinder head and excessories and buy an RB26 cylinder head. By the time you do the inlet manifiold, cams (RB26 cams are always cheaper), pulleys, bypass the VVT, lifters, valve springs, valves and then injectors (top feed are always cheaper), the fuel rail (the standard RB26 rail is good for over 650 bhp) etc etc.
Then you have the fact that the end result (of a hybrid RB25 cylinder head) is never as good a full RB26 top end.
Cheers
Gary
I havent looked at the 26 plenums in detail... but couldn't you just plane off say 5mm from the first components that bolt to the head (do the throttles bolt directly up to the head on a 26?? I had a feeling they have a small manifold piece between the head and throts...), and get a 25 flange laser cut out of ally, and weld onto the planed off area? That would seem like the most simple, and cheapest method to me... mind you, i haven't looked at the 26 and 25 inlets in detail...
Laser cutting ally is cheap as... hell, take the laser cutters a new gasket for a 25 and they'll be able to cut you an ally flange piece of piss... (ie. used as the stencil)... it might cost you what... $100-150? maybe less (for the flange)... welding it would be the more expensive part, but even that should only cost a couple hundred at most... (welding + grinding the inside ports clean)
Maybe im heading off on the wrong track here, but I just haven't had time to look at the two inlets in detail...
I'm going single throttle body with the GTR plenum welded to stock runners, hopefully it turns out alright :down:
 Share
    • I have S15 helical too. It is a bit worn. I think the drive behaviour you describe is related to this wear. Wear of helicals is something that no-one seems to have paid a lot of attention to, but now that they (as in original Nissan ones) are all a bit old - we're starting to  see the consequences. The ends of the helical spurs wear into the casing. That's where they perform the braking that diverts torque. Some of the more modern helical designs have proper wear surfaces introduced there, but the Nissan ones are just steel on steel (or iron).
    • I've had a range of rear diff centres - open, viscous, helical, mechanical, welded, etc.   I can't go past a refreshed factory 32 gtr centre for consistent lock and street driving. The next step up for me would be the nismo 1.5 way , which likely suits you better as track sounds like the focus. Will chatter in carparks but its not the worst.   I have never tried a quaife rear diff, an option I've looked at before and might be one for you .....   Currently playing with an S15 centre at the moment and I hate it.  The transition from single wheel spin either side is just weird.
    • Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
    • I also run a CD009. I'm currently on a 4.08 and it's not great. I originally intended to run a 3.3 but had issues, more on that later. I'd stick to anywhere between a 3.3-3.7 as found in the 350z.  As for brands of ring and pinions, absolutely stay away from Speedtek. They are absolute garbage. See my build thread for more information on that. I went through two of there 3.3's and both had bad runout. They were paperweights and they have still yet to refund me.  I ended up putting in a Nissan 4.08, which was better then the original 4.36 but is far from ideal. I'm going to pop a 3.5 in this winter. I'd stick Nissan. I've also heard of a company "Neat Gearboxes" that makes them. Haven't tried them, but they can't be worst then Speedtek...
    • You should Nistune the ECU, so you have freedom to use modern injectors instead of replacing with the same old shit. This is also required if you want to boost it up above ~200rwkW, where the stock injectors will be running out of capacity. Having said that, it is unlikely that the injectors need replacing just 'coz. If you imported it from Japan, the fuel should have been pretty good quality for the whole life of the car.
