Can This Be Complied?
The transmission should be no trouble as it's just about the same as what comes in the 260RS anyway, however this specific car has previous accident repair history so it would not be suitable for import to Australia ... the price is not so cheap either.
We're the sole Victorian agent for trade car view. The 0 doesn't always mean accident on tradecarview, it just means that the dealer on tradecarview hasn't given their car a rating yet. Or, sometimes cars which are modified also get a 0 because they don't grade them. The B is the interior rating.
I'd imagine this car would be about 2 mil, not 3. I think they have both 5sp and 6sp, so as long as the gear box is factory, should be fine about that.
How much accident/repair history is too much?
If the compliance workshop stick to the laws then ANY accident repair history is too much although minor paint repairs should be allowed - with that said there are workshops who will reject cars with any paint repairs just to be safe (overly fussy!) and others who will pass almost anything as long as the car stays together in their workshop (very dodgy!) ... personally I would suggest keeping well clear of any cars with known accident repairs and check all cars well before buying as most sellers will say 'no accident history' by default unless you prove otherwise.
We have dealt with many sellers from TradeCarView and found that most are very dishonest about condition at the very least, many do not even own the cars they list for sale. Some sell on behalf which means that they are guessing the condition and can't check because the car is not in their yard.
I agree that some sellers are honest and will list cars as accident grade (like this car with grade 0A) when they are unsure either way but most will do the opposite and note no accident history (like grade 4) for all cars even when they know or suspect otherwise. What I am saying is that you should not buy a car, especially from a frequently unreliable source like TradeCarView, unless you can verify the condition from an independent source - it's even more critical when the seller lists the car as an accident grade like this one.
Keep in mind that TradeCarView is a place where sellers list cars targetted specifically at international customers, these are mostly end users who will only ever buy one car and by the time it arrives in Australia and you realise that it's far below what you expected then it's too late and you can't do anything about it then.
Just in case you are still considering this car you should know that at the listed price it would end up costing around $45,000 landed and complied in Australia (at the current rubbish exchange rate), and as noted in this thread already you should be able to get a good one for around $25,000 landed and complied give or take.
  • 2 months later...
J Spec..just wondering if history of repairs, would replacing a slightly dented left guard interfere with import..i hit a snow bank and got the guard replaced. It was minor but in japan they replace rather than fix.
fine as long as it's not structural.
and if you are bringing it back to aus as a personal import then it's not an issue at all. the 'no accident repair' problem relates specifically to SEVS compliance. since you live in japan just export the car after 12months of ownership as a personal import and you do not have to have the car complied.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
