Item:GT 3540 .63 TURBO
Age:Less than 2000km old
Condition:as new
Price:1450 FIRM
To Fit: (What car)rb25 or bigger
Contact:0421 986 981
Comments:never been over 18psi which isnt even in its efficiency range so heaps more left in it. Just a tad big for what i want to do. Made 295kw on a full standard rb25.
Edited by LTHLRB
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/
  • Replies 56
yeah second hand gt3540's are worth anywhere from $900 to $1200, i picked up a brand new one for $1450 2 weeks ago.
drop the price to 1200 and you should be able to get close to that price
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3683980
this turbos hasnt even been pushed into its efficiency range yet. So its barely even been used. I payed 1800. Polished it. Put the metal elbow and did roughly 1500kz. So its still basically new. But i am negotiable. Be realistic im not gona go too low.
And u cant get them brand new from a shop for 1600. Min is around 1750
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3684688
approx 18psi. i dont want to push this any further because i have a single plate clutch and obviously the std bottem end, if it was a built engine with a twin plate, i would go up to around 26psi. For street this is more than enough to scare you.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3688505
To do the same setup i have done with this turbo is not a costly exercise.. Turbo cost me around 1800 then delivery, manifold was 250 then hadto modify it to be perfect, gate was 570.. You could use cheaper parts, but i dont want to stuff around fixing things twice, so i went braided everything and made another wastegate outlet with a screamer, full 3" exhaust, 4" intake pipe, Put the elbow on because if i was to put a silicone bend it would melt.
So realisticly the figures to set up everything would be roughly 3,700 or so doing it right.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3694845
So your including all of that + turbo?????
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3695077
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
