Item:GT 3540 .63 TURBO
Age:Less than 2000km old
Condition:as new
Price:1450 FIRM
To Fit: (What car)rb25 or bigger
Contact:0421 986 981
Comments:never been over 18psi which isnt even in its efficiency range so heaps more left in it. Just a tad big for what i want to do. Made 295kw on a full standard rb25.
Edited by LTHLRB
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/
  • Replies 56
yeah second hand gt3540's are worth anywhere from $900 to $1200, i picked up a brand new one for $1450 2 weeks ago.
drop the price to 1200 and you should be able to get close to that price
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3683980
this turbos hasnt even been pushed into its efficiency range yet. So its barely even been used. I payed 1800. Polished it. Put the metal elbow and did roughly 1500kz. So its still basically new. But i am negotiable. Be realistic im not gona go too low.
And u cant get them brand new from a shop for 1600. Min is around 1750
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3684688
approx 18psi. i dont want to push this any further because i have a single plate clutch and obviously the std bottem end, if it was a built engine with a twin plate, i would go up to around 26psi. For street this is more than enough to scare you.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3688505
To do the same setup i have done with this turbo is not a costly exercise.. Turbo cost me around 1800 then delivery, manifold was 250 then hadto modify it to be perfect, gate was 570.. You could use cheaper parts, but i dont want to stuff around fixing things twice, so i went braided everything and made another wastegate outlet with a screamer, full 3" exhaust, 4" intake pipe, Put the elbow on because if i was to put a silicone bend it would melt.
So realisticly the figures to set up everything would be roughly 3,700 or so doing it right.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3694845
So your including all of that + turbo?????
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3695077
