Looking to wreck my 33 GTS-t that happened late last year when some clever old lady thought it might be a good idea to run a red light. I bought the car back off of the insurance company and have had it sitting here since as I've been too busy with work and other commitments to do anything with it. In the last few weeks I've sold off the turbo and exhaust but everything else is still there. She cleaned right across my front so headlights, front bar, rad support are all rooted. I tried turning over the motor after getting the wreck back and can confirm it still runs fine. Car has approx 130000km's on the clock. Interior is mint condition apart from the dash and steering wheel where the airbags have deployed but seats, trim etc are all fine. She ran on white 17' BuddyClub P1's and I just put new rubber on them probably two to three weeks before the car was totalled so the tyres would have done under 1500k's.
Looking at getting around the $4000-5000k for the wreck, honestly I don't know if this is too steep but it's a starting point and I'm willing to negotiate. If there is enough interest in parts I will also be willing to strip the car off and sell parts individually...
Edited by heslo
https://www.sau.com.au/forums/topic/208148-1996-r33-gts-t-wrecking/
Most have been sold off already buddy, still have an RB25 PowerFC with hand controller and boost controller but I'm 99% sure that's spoken for by Madaz
yes spoken for :blink: Luke is my Angel , my knight in shining armour :thumbsup:
Luke im looking into getting my turbo reconditioned and am willing to put back on you engine so it is a DET again
how much u looking at for the motor and box together?? not worried bout the turbo or manifold. Id need the wiring loom and computer (if u have the stock one). And r the front calipers and rotors ok or were they damaged in the accident?
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
