Looking to wreck my 33 GTS-t that happened late last year when some clever old lady thought it might be a good idea to run a red light. I bought the car back off of the insurance company and have had it sitting here since as I've been too busy with work and other commitments to do anything with it. In the last few weeks I've sold off the turbo and exhaust but everything else is still there. She cleaned right across my front so headlights, front bar, rad support are all rooted. I tried turning over the motor after getting the wreck back and can confirm it still runs fine. Car has approx 130000km's on the clock. Interior is mint condition apart from the dash and steering wheel where the airbags have deployed but seats, trim etc are all fine. She ran on white 17' BuddyClub P1's and I just put new rubber on them probably two to three weeks before the car was totalled so the tyres would have done under 1500k's.
Looking at getting around the $4000-5000k for the wreck, honestly I don't know if this is too steep but it's a starting point and I'm willing to negotiate. If there is enough interest in parts I will also be willing to strip the car off and sell parts individually...
Edited by heslo
https://www.sau.com.au/forums/topic/208148-1996-r33-gts-t-wrecking/
Most have been sold off already buddy, still have an RB25 PowerFC with hand controller and boost controller but I'm 99% sure that's spoken for by Madaz
yes spoken for :blink: Luke is my Angel , my knight in shining armour :thumbsup:
Luke im looking into getting my turbo reconditioned and am willing to put back on you engine so it is a DET again
how much u looking at for the motor and box together?? not worried bout the turbo or manifold. Id need the wiring loom and computer (if u have the stock one). And r the front calipers and rotors ok or were they damaged in the accident?
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
