Whats your budget!?!?
What do you use the car more for?
drags? track? street? show?
I want a show car but i also want to bae adle to pop the hood and show people its not just a show pony.
Hey i've got a r33 with a rb25 in it, im thinking about pulling it out and putting a rb26 in. Just seeing if anyone thinks if its werth it, or if its better to do up the rb25.
Cheers.
i blew my RB25 + turbo a few months back, and just now ive got it back on the road. i bought a replacement RB25 package, that came with bigger turbo, injectors, fmic, plenum etc etc. up and running now it cost me $6000 parts and labour ($1300 of which was just to fit the damn fmic) but its goes hard now, bit laggy, but shitloads of top end. 240kw at the treads running 16psi, and i would expect a 12.7 or possibly better 400m.
so yeh could be an option for you, i can even make some money back by salvaging parts off the old motor!
id say a stock RB26 + bits would cost you upwards of $5000, plus $3000 to fit. for maybe 180rwkw or thereabouts. but you could sell your old 25 to make some $$$ back. but youre still some 60kw short of where i went... something to think about...
oh and my avatar is my new donk :thumbsup:
dude search rb25s people have built, go through cars for sale etc. Can easily make 300kw safely which is more than enough, good for a mid 12. RB26 is a waste of cash unless u want a monster, better off selling and buying a gtr if your thinking of going that route, then you get better brakes, suspension, seats, and 4wd.
Im seeing the light. The main thing i don't want from the car is lag. I just want it to be quick and responsive for the street, so i came beat any comidor off the lights. haha :thumbsup:
oh my car is laggy as fudge. which basically means its not good for getting sideways etc. off the lights you can launch it with barely any wheelspin, and then it just hooks up and keeps going. you just have to keep the revs up to it. will destroy any commo/ford, unless of course they are heavily modified too.
its great for drag racing. not so much for mucking around in.
response and top-end is a compromise. you cant have both. well from a limited budget anyway. :blink:
response and top-end is a compromise. you cant have both. well from a limited budget anyway. :D
Dude,
If you have 240rwkw your turbo cant be massive, so it shouldnt be THATT much laggier than stock. do you know what sort it is?
-Dragonforce
Dude,
-Dragonforce
its a kkr430 running 16psi. its not enormous by any means, but when coupled with a rather large fmic and a big plenum, doesnt help. it doesnt get much power until 5000rpm, and really takes off at 5500.
its going back for a final tune in a few weeks, i would like it to be a bit more usable. its A LOT laggier than stock. the first thing i noticed, put my foot down in 2nd and nothing happens. brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrwhirrrrrrrrrrrrrrrROARRRRRRR PT-CHHH!! hahaha
its not so bad now because i am learning to keep the revs up to it, but when you change gears there is more lag than before too.
I just want it to be quick off the mark, heaps of fun to drive and be able to drop it back and take off. What sort of a bugget did you think i wond need?
if you have no mods whatsoever, i would say exhaust first, pod filter, injectors, wastegate actuator. all fairly simple, and decent power gains, 170-190rwkw for $2000-3000. then you can look at bigger turbo, intercooler, plenum, engine management, clutch, fuel pump, bov... for more serious power. probably up to 220-250rwkw for another $4000-7000.
it aint cheap. but most things you can get 2nd hand if youre not too fussy. just remember, the poor man pays twice. i replaced my stocko clutch 7 months ago, and now i need a new one for my new level of power.
if you can, have a drive of a modified skyline, and see how you like it.
Mate if I were you I would just do bolt ons with supporting mods and go for 400rwhp. With a correctly sized turbo it shouldn't be "that" laggy.
My mate is putting a rb26 into his r32 and going single turbo at the same time. He's budgeting somewhere between "10 - 15k" and he is doing alot of the work himself, and in the end he is still limited to about 450-500hp because the engine will still be stock.
Are you going to throw a bucketload of money at the engine as well as fitting it?
If not, the fact that you wasted money fitting a stockish RB26DETT instead of doing up your existing RB25DET would tell people that you're driving a show pony.
The fastest stock Commodore available is the HSV E-Series GTS at around 13.2s. Getting an RB25 powered R33 to do a high 12 shouldn't cost as much as doing a complete engine conversion. According to the Time Slip Registry, this guy ran a mid 12 with 215rwkW. Other people are telling you that you can get that power, or more, for less than the cost of dropping in a stock RB26.
And "any Commodore" is a pretty wide swathe. There are some insanely fast street-driven modified Commodores out there.
However, "responsive" and "turbocharged" are two mutually exclusive things. Especially when you start dialling up the power and boost. If you want a powerful engine with instant throttle response, get a V8.
ouch, im running the bigger version kkr480 and i make 19psi by around 4600rpm or there bouts...
i think u have ur adjustable actuator rod 2 loose which makes the kkr turbos laggy as hell... tighten it back up, the kkr430 should make 1 bar at aruond 3500rpm... mmm
build up the 25. for the price of a 26 install you could have a darn fast 25.
as far as i know the kkr turbos are only bush bearing so they will have more lag than a ball bearing. UCD15R33 has a 3076r (which is a touch bigger than a kkr480) on his 25 and it spools up pretty well and it spooled up pretty well, even with 1 cylinder that turned out to be stuffed.
if you get a good ball bearing turbo that is overkill you should get good repsonse as well as top end power. and as has been said, you can always go the rb30 bottom end to pic up low down power.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
