if you have no mods whatsoever, i would say exhaust first, pod filter, injectors, wastegate actuator. all fairly simple, and decent power gains, 170-190rwkw for $2000-3000. then you can look at bigger turbo, intercooler, plenum, engine management, clutch, fuel pump, bov... for more serious power. probably up to 220-250rwkw for another $4000-7000.
it aint cheap. but most things you can get 2nd hand if youre not too fussy. just remember, the poor man pays twice. i replaced my stocko clutch 7 months ago, and now i need a new one for my new level of power.
if you can, have a drive of a modified skyline, and see how you like it.
I've got exhaust, pod, intercoller, fuel pump, cluch, bov and coil packs done already. Im sorta got a bugget of 14k, a bit of that will go into engine delailing. If i end up needing more cast ill just have to work harder. How relistic is 400hp?
Mate if I were you I would just do bolt ons with supporting mods and go for 400rwhp. With a correctly sized turbo it shouldn't be "that" laggy.
My mate is putting a rb26 into his r32 and going single turbo at the same time. He's budgeting somewhere between "10 - 15k" and he is doing alot of the work himself, and in the end he is still limited to about 450-500hp because the engine will still be stock.
Im looking for arond 400hp
any reason why you can up with than number? why not just build the car up with a good sized turbo so that it has down low power and plenty up top and go from there, rather than set your goal at a certain number or certain 1/4 mile time. you might get 400hp and have a car that is laggy as hell, and while you may be happy that you made 400hp, someone with 350hp may leave you for dead, and have a car that is much more responsive and much more fun to drive.
as someone said before, try and take someones car for a drive that has a few mods done to it and see what you think.
and why do people list a BOV as a performance mod? LOL
400hp was just want i was looking for, dosent mater if lest as long as its nice to drive.
Edited by Stevemc88*
A thoughtfully modded 25 is a dynamite street package. My mate runs such a setup with around 260 rw killer wasps running basic mods.
hi flow
front mount
injectors
fuel pump
splitfires
Turbo back zorst
power fc.
decent clutch
It hauls arse and is very very driveable. Full boost around 3000 rpm and mid range to die for.
If its a solid street package you are looking for that is the way to go.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
