Hey Guys,
I have recently imported this Drift Spec Sil80, which I was inteding to use for drift.
However working 55hours a week has left me very little time to do anything else.
I'm after $12,000, or swap for a Manual R33 Gts-t
Nissan SIL80
1993
SR20DET
82,000km
5speed Manual
WITH VERY LONG LIST OF MODS:
*S13 Silvia front conversion
*Custom Purple Pearl Paint Job
*Aero Spec Side Mirrors
*Zeal Coilovers
*Roll Cage
*17Inch Work Wheels
*Aftermarket Fuel Pump (brand unknown)
*Re-maped ECU
*HKS 2560 Turbo
*Aftermarket Exhaust Manifold
*SARD fuel regulator
*Nismo 550cc Injectors
*HKS Front Mount Intercooler
*3inch Exhaust System including dump pipe and high flow cat, with twin cannon mufflers.
*Blitz Dual Stage Boost Controller SBC i-D
*Nardi Steering Wheel
*Apexi Tacho Meter
*Various Greddy Gauges on passanger side
*Bride Drivers Seat
*Heavy Duty Clutch
*Short Shifter
*Full Body Kit, (unsure of brand/type)
*BLITZ blow off valve
*BLITZ airpod
*Aftermarket Oil Cooler
*Aftermarket Radiator
PLUS THERE ARE PROBABLY MANY OTHER BITS I MISSED
I'm running the turbo on a very conservative 1.2Bar at the moment, at which it made 242rwkw
Its currently uncomplied, but I have all import papers so it CAN be complied.
Here's just a pic taken on my phone, i'll take some more tomorrow.
https://www.sau.com.au/forums/topic/208199-drift-sil80/
Is it and can it be complied??
It CAN be complied, it was imported through raws, not CAMS (race-use only)
which means I have import approval and all paperwork, so it CAN be complied and road registered.
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3738522
ignore that it helps if i read the whole post lol, how much for compliance any internal work ??
depending on which raws workshop you use, but the ones in sa all charge around $3000
and the car needs to be as standard as possible, so it would involve a bit of work, which if done by a workshops wont be cheap!
Thats why its best suited as a track car
or it would suit someone that has all the standard parts and a bit of time on their hands to do the work themselves.
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3738534
It is possible to make the car standard your self, and then give it to them..
Have a search you might be able to do everything, then get them to tick the box's.
Just trying to get a hot car a new home....lol
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3739697
yep all the work can be done yourself, and then just give them the car as standard as possible to comply
It can get complied as a sil80, so the lights, fenders and bonnet do not have to be changed.
Edited by Tommmo
https://www.sau.com.au/forums/topic/208199-drift-sil80/#findComment-3739890
