Hey guys my names Paul.
This is my new 4 door r32. Picked her up fair cheap.
Its stock at the moment apart from a turbo timer, and a pody.
Its a bit rough with a few electrical demons. Car locks and unlocks it self when started, turbo timed unlocks car when finished if cars locked. And oil pressure works intermittently.
But happy because I have time to work on it and fix it up.
Future plans include some kind of fuel cut thingy??? I am having boost cut problems when i rev past 5-6ish rpm. I think i need a FCD or a SAFC???
Want to get a r34 side mount, r34 turbo, exhaust, and boost it a little bit.
Here are some pics for ur viewing pleasure.
Also want to get a gtr front lip and maybe ditch the rear wing when its lowered on some coil-overs
But its gonna stay fair inconspicuous, don't want to be harassed by police.
https://www.sau.com.au/forums/topic/208208-n00b-4door-r32/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
