Nice work, I intend on making on of these, my question is ; What else from around the house can I use to heat the perspex
$15 heat gun from bunnings, otherwise blowtorch & wrap the perspex in tinfoil to stop it burning
toddlls idea isnt bad, but I found it was much easier seeing where the perspex was that I was melting.
BTW, I tried a normal hair drier and it didnt work :)
honestly, at bunnings I bought a cheapy heatgun for $12-15 bucks and it worked a charm. within 30 seconds it was almost like honey.
Gl with it.
Adam
  • 3 weeks later...
  • 7 months later...
your welcome guys,
also turael, i'll try to get some pics up over the next few days, cant believe its been in there for almost 2 years! But i can tell u now, run over it with a wet cloth and dry... still looks like the day i made it.... and I will prove very soon.... Not to mention i have taken it out to work on things and rested tools on it heaps of times!
Not a bad idea, the Perspex looks good. I made my own also, although I went a different way. Is yours actually fastened to the body? or just sort of slots into place?.
either way looks good, Top job.
I must say after 2 years it still looks great!
I was thinking of making a hole in the top and make a fibreglass tube from the snorkel into the top.
Will post pics when I'm done!
  • 4 weeks later...
OK first up i gotta say that the heatshield looks awesome.
BUT... I have to ask...
You used perspex to make it from (I guess it's good coz you can still see the pod somewhat), and you used a "heat gun" to shape the "heatshield"....in other words since perspex changes shape with heat, how hot does the engine bay have to get before it melts??
very hot dude, like yeh if u placed the pespex on the exhaust manifold it would melt... but if you look it up on wiki:
http://en.wikipedia.org/wiki/Poly(methyl_methacrylate) its melting point is 130-140 degs celcius
and the heat gun was direct heat, whereas you'll find the heatsheilds normally just suffer from indirect heat like heatsoak from a hot motor...
Adam >_<
Im keen on doing something like this for summer, oh and wicked job btw.
Does anyone know of a more heat resistant material to use? maybe some aluminium sheet metal with heat sinks around lol.. a little over the top?
Also have you had any problems with police? or is it perfectly legal?
thanks.
If anyone has some air temperature sensing equipment I could borrow to give some results, or if someone can point me in the direction of where to buy one within the $200ish mark i'll get some results.
I bought a fairly cheap 'automotive' multimeter from dick smith ot radio parts a while back which also came with a K type thermocouple or what ever they are called. You can plug it in and run the wire to the air box etc. Unfortunately you don't get two sensors two compare at one time but you do get a multimeter out of it too. Maybe one of your mates wants one too and then you'd have two readings?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 馃槀
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
