Hi all,
As the title goes... do I need to use a rocker cover gasket on an RB25DET (neo)? ie. is the standard gasket rubber or cork where it has a significant thickness, or can I just silicone it?
Also if I need to use one does anyone know where I can get one...?
Sorry this seems like an obvious question but I did a search for 'rb25 rocker gasket' and got nothing.
thanks!
DaveB
https://www.sau.com.au/forums/topic/208241-rb25det-neo-rocker-cover-gasket/
yes you do need one because if you don't have one you will have oil leaks :D and to get one just go to nissan :(
Cheers
Chi
Cheers Chi :(
So does that mean silicone alone won't work? Or even if I re-use the gasket that's there (is it rubber?) I'm expecting a Nissan gasket to be expensive...
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
