Hey guys, just lowered my r33 gtr on coilovers, not too much just a good height, and my camber seems excessive now, this is from me looking at them....maybe ~2negative all round?....i havent done my wheel alignment yet, but i dont think itll help much.
Whats my best option at this stagE?, i can get whiteline stuff locally and cheap aswell....
also whats a good camber setting for the gtrs?
Edited by r33turb
I wouldn't call -2 excessive.... maybe a bit much on the rear....
But i guess it depends if you want tyre life or better handling...
You can get some adjustable arms (cusco etc..) or some bushes like the whiteline ones, you can order direct from them or check out Sydneykids whiteline group buy on here.
Camber settings depends on what you want, tyre life or handling... whiteline have some recommended settings on their page, take a look.
If you lower it and don‘t correct the excessive negative camber you will suffer from rapid tyre wear, as well as reduced traction for handling, braking and accelerating. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Keep in mind that GTR's handle best around 355 mm front and 345 mm rear (centre of wheel to guard).
Group Buy link http://www.skylinesaustralia.com/forums/R3...tel-t87826.html
Cheers
Gary
Thanks mate, do you have the part no's for the camber kits i need (front/rear).....
PM me for details and pricing, it's in the Group Buy thread as well, just click on the link above.
Cheers
Gary
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
