New Holden Coupe...
Yidz
 Share
  • Replies 75
I predict that by the time this car reaches production:
No side mounted exhausts
B Pillar installed
Racing seats removed
Racing harnesses removed
Still, damn hot car that's for sure.
the other points in your post hold some merit, i think the contrary, but whatever, if it does see production, many aspects will change.
as for the bit about the holden badge, open your bollocksing eyes. stop being so damn single minded. its attitudes like that which cause so much trouble in the automotive 'enthusiast' scene.
appreciate the car for what it is, dont simply write it off because of the badge.
made me lol edit, bollocks. nicely done to whoever set that up.
Every thread that is to do with holdens he posts the same shit.
Vietorous, can you post a pic of your car? You are so unbelievably single minded about things. So bollocksing what if it has a holden badge. Do you like the new GTR? If so, how can you not atleast respect the look of this car? Its not that far off it and shares a lot of similarities in design. But I forgot, R33 GTS-T's are the be all and end all of cars and because you've got one, that makes it sick..
Remember it's got a Holden badge. He thinks every Holden is crap. Probably never had any real experience either, other than riding shotgun in a mate's worn out VP V6 for 5 minutes.
Never liked him, or his opinions.
Edited by RyanVLSL
Just poking a little fun. I respect people and their choices on the car - I have mates that drive Holdens and sure I crack a funny one here and there but its all fun and games.
My attitude doesnt cause trouble in the automotive enthusiast scene - the attitudes that do are the ones who says it seriously and takes it seriously. Friendly competition doesnt hurt.
Whats a pic of my car got to do with anything? When did I ever say my car is better/be all end all/fully sick? I'm just posting an opinion on the car of topic and cracking a funny one. :) Harden up - dont like my post theres an "ignore user" option in my profile - use it.
Edited by vietorious
I dont like you or your opinions either.
As stated below - use it.
I think it looks pretty good really and borrows a bit from the new Camaro, except there's something about the back wheels setup which just seems a little bit odd and not quite with the rest of the car.
push rod engines dont rev, dont make power, and are clearly handicapped.
:P
You are joking about the don't make power remark aren't you? Bolt on a twin turbo kit onto a LS1 with just upgraded valve springs and you'll see 400rwkw. Bolt one onto a LS2 and you'll see 450-500rwkw.....How on earth is that not power?
looks f*kn tuff
i would buy one
and on the whole pushrod argument, and yes we've heard it all before
its relatively old technology compared to twin cam etc
but GM are still using it coz its still quite an effective set-up
personally im waiting for the big quad cam donk to start production in the near future hopefully
It's f*cken hooooorrrrrrrrn. I saw it at the motorshow today. Wheels are awesome and the tail light design has segmented illumination. It's really hard to describe but looks great up close.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
