Lakeside Track Days
Hey Guys,
I have been talking to Keith from Queensland Raceway and they are planning on having the calendar for Lakeside sorted out late next week. At this stage nobody has been given any firm dates. The Time Attack day will be the next private track event held at Lakeside. We are also up the top of the priority list for dates this year.
Paul
  • Replies 101
whats going to happen with noise restrictions at lakeside?
alot of the timeattack entrants arent exactly quiet?
I can't wait for the opportunity to have a drive there.
Michael
Michael
the noise limit was 92db last Wednesday. If you were over that, you got sent home - no refund. I'd say that's what they're going to stay with. So make sure your car is quiet before you go to Lakeside - it will save you money/hassle, and it will keep the local residents happy - well, as happy as possible. Noisy cars will ruin this for everyone.
I don't think so. If the noise limit and conditions are made clear before you enter, no problem. The possibility of forfeiting an entry fee might make people make sure their car is quiet enough before they go out there - which is best for everyone. If Lakeside is to survive, noise restrictions need to be taken seriously.
should add its a 92db drive by restriction - so you're on the track when you are measured.
Edited by hrd-hr30
good-o 92db at which distance and on which side of the car (please say right, please say right, please say right)
I would suggest noise measurement would be from the outside of the track, which is where the houses are. That would make it left side of the car. However as you know pits is on the right side so maybe they stand there? HRD-HR30 would know more having been there.
yeah there gonna have to be tough!! when i was there the other day a motorbike cruised around the track at about 60 kph and it was fairly quiet, when i went up for a drink ( about 5 miutes later)
they lakeside guys were on the phone talking to a local complaining about the noise of the bike!! :)
Edited by giant
Apparently there's just one particular resident who does the complaining, a lady who evidently isn't into racing.
Re the Db meter, it was positioned on the wall below the tower, so, on the right side of the car. That's not to say it won't be moved in the future. Maybe someone involved can tell us if it's gonna be in a fixed position?
I assume the meter looks something like this (but no weather gear of course):
So maybe if someone used something like this:
....everybody would be happy. Except the little old lady who complains cause she's got nothing better to do, but Australia has pretty much always been a "majority rules" country anyway :P
 Share
    • Hi and welcome. What are you planning to do to the car or will you keep it stock?
    • https://windowmotor.com.au/collections/02-07-v35-nissan-skyline?srsltid=AfmBOorAnTNYaD1tXzczAKZFqnDkZy23WgPXNfVscyeRKHhVNkiaC-WH https://www.gumtree.com.au/s-v35+stereo/k0
    • Heaps of historical info on this, a quick Google gave dates back to 2012, all talk about identification markings, dimples, shapes of mounting surfaces, washers, that are concave or something to match the fasteners mounting surface, which ARP states that if the washer, if it uses a washer in its application, isn't the right way around, it can cause premature failure,  even if it was torqued up correctly with whatever lube is meant to be used There is even talk about getting the bolts Xrayed to check the structure, one was about some builder getting multiple sets of bolts, having them Xrayed, and picking from those results Nowadays identical "looking" fake parts, in identical looking fake packaging are everywhere, with all the markings and stuff, the only way you know they are not legit is Xray or when they fail I assume if you don't want fake parts, and don't have a Xray machine handy, is to get them directly from ARP in the USofA, aftermarket rod and head bolts aren't something to take for granted  Imagine building a big dollar build only to find you lunch it because of an inferior fake fixture let go 😫
    • Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28"  Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 )  Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October )  Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge    20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
