Official Launch At Melbourne Motor Show
sewid
 Share
just going by what mr engineer said.. i didnt look inside :cheers:
hmmm, well im going to sit on the fence on that one. A senior Japanese gearbox engineer told me there would be no manual but according to many the rumors are reported that it will. No point guessing. The proof is when i actually see it - likewise with the speed limiter.
  • Replies 72
just got back from another drive in the thing. It was wet tonight and there was plenty of traction loss. I really believe the tyres are losing traction because of the cars weight but meh, i could be wrong..
Its nice to have a mate who owns one though! :cheers:
That doesn't make sense.
Glad you had fun though!
lol, yeah Sewid, i dont understand it... i suppose it was because of the greasy shinjuku streets but taking off from the lights it was slipping and slipping - not clutch but traction, yeah? Strange.
But yes, anyways, a lot of fun none the less! It is a great car.
oh and as a side note, koichi is 6 foot 4. Tall bloke by japanese standards and his head was like, almost touching the roof. Again with his seat set the way he had it, there was only an inch or two between the back of the drivers seat and the passenger seat.
Im glad i dont have to sit in the back!
So how are things working out with you two?
lol, just peachy thanks, Laurence. :cheers:
Hows that relationship with Brie coming along?
Edited by m3gtr
Good to hear, I gotta get myself a Koichi...
actually I have just finished vomiting from food poisoning. I think Brie and I need some time apart.
Edited by Laurence
hmm, if youre ever in tokyo i can let you borrow one. :cheers:
Dont tell me, she made you sick? What a bitch Brie is. I told you she was no good mate.
Edited by m3gtr
sounds like only thru nissan
*sigh. personal import will always be an option regardless of what nissan do or don't do. it is the low volume SEVS import method which has a question mark over it.
Nissan might try and pull the sit one in the show room and say it is sold or as for Mazda and the RX7 it had $150,000 price tag which no one would pay so DOTARS worked out what Mazda were up to and took approval off them which allowed RAWS approval for the post 9/99, Toyota and Mitsubishi also tried the same type of thing stopping SEVS import but DOTARS said they were not meeting the Full Volume requirements and took full volume approval off them.
If stocks of the R35 GTR are not in the show rooms around Australia and 6 to 12 month wait for more cars coming into the country or they go sorry all sold come back in 12 months that is not meeting the full volume requirements and they should be SEVS eligible.
its not gonna have a manual, because the box is in the rear end of the car.. theyre not gonna run a 2mtr long connector pipe thingy from the inside of the car, to the rear.. it'll become to clumsy, its bad enough on FWD cars let alone one with the box in the boot.
Plus a manual trans will shift too slow compared to what it has now :ninja:
That is not the reason they wont have a manual, plenty of other cars have had rear mounted manual transaxles.
Plus a manual trans will shift too slow compared to what it has now :)
Porsche did it... so have Alpha Romeo and a bunch of others... if not 90% of transaxles...
90% of transaxles?? the GTR is the first to have a rear mounted independant transaxle.. so plenty of other cars DONT have it because the GTR is the only car that has it atm.
btw.. porsche have the engine with the box in the rear end.. its a different type of transaxle altogether. theyre setup is like every other FWD car ever invented. as alfa and everyone ur thinkin of
Edited by Bumblebee
The GT-R is in no way the first car to ever have a rear mounted independent transaxle. Do some homework before thinking you know everything geez. Plenty of other cars have and plenty of those have been manuals. If the yanks could do it back in the 90's with the C4 corvette im sure Nissan could figure it out if they cared to.
do some homework?? lol tell that to the whole world then. the gtr is the first to have independant rear transaxle.
Thats what they claim, and they wouldnt get it wrong :D
"The Nissan GT-R features a newly developed Premium Midship package, including the world's first independent transaxle 4WD developed independently by Nissan. "
i missed the 4wd part.. but its still the one and only going around
Edited by Bumblebee
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
