Can anyone provide any information/wiring diagrams for R33 Airbag systems?
Here is what i have figured out so far.
R33 GTR S1 have a big fat airbag, and look like this:
Behind the airbag is this black box:
Behind the steering wheel is this:
Coming from out of the circle thing behind the steering wheel (called a clock spring i think?) comes just 1 cable/plug. 4 wires, which plugs into the black box in the 2nd pic. From that black box comes single wire for the horn, and a 2 pin cable which plugs into the airbag.
R33 GTS S2 (1996) and R33 GTR S2/S3 (1996+) have the same looking steering wheel, like this:
Behind this wheel i have found 2 different layouts.
One has a Silver metal box similar to that found in the S1 GTR airbag wheel, a bit smaller, and same setup, 4 wire plug going to this box and 2 wire plug coming out of it into the airbag. Looks like this
The other layout has no box at all behind there and just a wire for the horn. I'm pretty sure that the clock spring behind the steering wheel has 2 plugs coming out of it, one for the horn and one 2pin that goes straight into the airbag... and has a transparent peice of plastic where the other wheels have a box. Like this:
Does anyone know what the box inside the steering wheel is for, the silver or black one that takes the 4 pin wire and outputs a wire for the horn and the 2 pin connector for the airbag?
https://www.sau.com.au/forums/topic/208318-r33-airbags-and-steering-wheels/
sorry ferni dont mean to hijack.
what a coinsidence, i was about to post some help asking how to get the airbag off. i have a metal weight ringing around everytime i turn my steering wheel. kind of like a loose klunk sound. metal on metal. now it hits my horn, so when i turn the wheel (a corner) the horn goes off. its driving me nuts and other motorists who think im crazy
i seriously cant find out how to get the wheel off.
any help from anyone would be awesome
also ferni howd you score a new steering wheel? i need one badly.
cheers
Edited by jake33
It's easy to remove the steering wheel.
There are 2 small black plastic covers to the right and left of the steering wheel, remove them, behind there, there is 2 T50 tamper proof torx bits (you can buy a set of them for about 10 bucks from bunnings or anywhere). Remove them, then the airbag/center will just pull out.
Better to not unplug the airbag if you don't have to, you can get to the bit you want to remove without actually unplugging the airbag. A big phillips head screw driver and you can remove the 2 screws holding the bit that is making the noise, either fix it and put it back in or just leave it out.
As for a new Steering wheel - put up a WTB in here, or keep an eye on the FS section, or contact a wrecker, or get one from yahoo auctions japan :)
as victorians will know i had a pretty bad accident with the airbags going off
when they put them back in i had a red light on the dash telling me to check them
this was because the sensor in the center console of the car was damaged and that tells the car that the airbags have been re fitted.
(according to the repairer)
the passanger airbag in a S2 breaks the windscreen as it pushes the flap of the dash in a upward direction creating a impact with the lower half of the windscreen
airbags stink alot, and fill the cabin up with smoke.
As for a new Steering wheel - put up a WTB in here, or keep an eye on the FS section, or contact a wrecker, or get one from yahoo auctions japan :P
ah cheers mate. yeah i thought it so... there is just so much going on in there i didnt know where to start. not to mention im paranoid as hell the airbags going to go off in my face!
cheers for the help
if you car has the module in the steering wheel it wont have one in the center console, SSS pulsar is the same
the yellow circular part is the clock spring or contact reel which just carries the wiring for the horn and the airbag
Great information, and this is what i thought, but wanted someone to confirm.
If you have a module/sensor under the centre console then it won't have one inside the steering wheel. If you do have one in the steering wheel it won't have one under the Centre Console.
So to confirm
95 R33 GTR S1 have the sensor in the steering wheel, and not under the centre console.
96+ R33 GTR S2/S3 have the newer type steering wheel with the sensor under the centre console, and none in the steering wheel.
So If the drivers airbag goes off, you need to replace the airbag AND the sensor, depending which one you have - either in the steering wheel or under the centre console.
Can you confirm this info is 100% correct 2GU UP?
  • 1 month later...
  • 1 year later...
  • 3 weeks later...
Hi Mate,
This topic has been covered a few times but you cant put a series 2 wheel on a series one and have the airbag work. Ive tried to but apparently its got something to do with the series two wheels being connected with a passanger airbag.
Unfortunately series 1 owners are stuck with the ugly series 1 wheels or putting an aftermarket.
I ve managed to fit a series 2 wheel to my series one.
All you have todo is connect the horn wire from the steering wheel to the blue wire
coming out of the clock spring.
However your airbag light will stay on and you won't have a working airbag
so I removed the airbag bulb from the back of the dash cluster.
I figured if your going to put a aftermarket steering wheel you won't have an
airbag anyway. At least this way it still looks factory if the police pulls you over
and it updates the interior at the same time.
  • 2 months later...
Sorry to post in an older thread but i am also interested to trace the horn wire back to the engine bay.
The person who owned the car before me had the metal weight in the airbag steering wheel come off and activate the horn randomly. All he did was disconnect the horn. Since then the relay has burnt out and so has the wiring from the realy mount to the horn.
If anyone can enlighten me as to what wire i need to tap into to re-run the horn wire that would be great
Chris
  • 1 month later...
cheers
Mine's f**ked too. How did you go with it? Did you end up getting a new steering wheel? I'm thinking of either getting another series 1 wheel or the whole series 2 dash+wheel (if the airbag works, just for the missus).
  white180sx said:
Hi Mate,
What if you buy the series 2 dash with the series 2 wheel? Will that now work? I heard they work hand in hand but not 100% sure. The only other issue would be the loom.
  • 1 month later...
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
