go c jeff from speedlab he works out of turbo tune he the man to c.
http://www.nissansilvia.com/forums/index.p...howtopic=279227 an remaps not just for ppl who hav couple mods fully bult sr using a remap no probs at all
are you being sarcastic or just didnt read the thread?? haha
hey drift pig let me know on the 26 plenum adaptor plates cause im looking to use the 6 throttle n plenum set up on a 25, that will make your 20 alot more responsive :D
  • Replies 67
Hey Danny, Thought you weren't getting another car LOL. Jump on MSN if you have a chance.
Yeah, The guy is on here, he's making them for 25's as we speak, he's looking in to getting one made for a 20.
If it's all to hard Ill just go see LeRoy @ BTR and get him to make me a custom Jobbie.
Truth be told, Shaun @ Boostworx (My Tuner) Said only to expect to see a 300 - 500 RPM increase in respone from a forward facing plenum, get much more gains from cams and tuning. Im mainly doing it to gain that 500 RPM, easy access to the plugs/copilpacks and a tidier engine bay. SHould be at full boost by 4000, so a 4500 rpm powerband is pretty awesome for a 20 in my books. Should be pretty easy to live with. If not, there's always cams, then nitrous LOL
Gonna slap my turbo with injectors/afm and see how she goes first I reckon. More worried about smashing the box into a million billionty pieces than a plenum ATM LOL.
Edited by R31 drift pig
i was doing it for clearance/response and bigger power down the track.. (25 in s13) but its the 6 throttle that gets the most response.. otherwise i would just grab a greddy copy plenum!
hey drift pig let me know on the 26 plenum adaptor plates cause im looking to use the 6 throttle n plenum set up on a 25, that will make your 20 alot more responsive :)
is the been sarcastic directed at me if so im at a lose y i just posted a link to a car jeff tuned that has a fully bult motor as proof wat a remap can run. as sum ppl dont think u can hav lik 850cc injectors etc
Edited by 4dirty2
sorry dude, but i can't stress enuf about changing your mechanic either. don't wanna be the bearer of bad news but i use to go to AMMR and after a mate of mine noticing sumfn wrong in my engine bay and steve not picking it up after going to him for a few years, i'm convinced he doesn't know skylines. Like i was told, there is either the mechanic that knows what he's doing with a skyline and does it or a mechanic that doesn't know what he's doing and does it neway! Doesn't that just piss you off :)
sorry bout my lil rant :)
I totally agree, dont really want to go into what happened, but i had him as a mechanic for a while until there was a simple service done and i drove out of there with battery acid leaking all over the engine bay and onto the front bar.
He also wanted to run 16psi on standard turbs and internals???
hey, how long have you had ur 34? i reckon i remember seeing it down there ages ago. he did ur intercooler didn't he?
Had it bout year and a half, yeah had the cooler done there. I should of left when some other drongo that used to work there stuffed up my cooler for my corona!
Which car is yours?
got a black 33 with a lil drift spoiler, doesn't look nefn special cos it's got standard rims but i got an intercooler thru steve and he did my clutch and intercooler at the same time cos my clutch broke as i was saving for putting the intercooler in, suggested i do the intercooler when he does the clutch. was the last thing he did to my car, asked for a quote to fix my clutch cos the box at the top(weld broke) was loose and the price he told me was more than the quote i got from tilbrooks(only just started getting my car serviced there at the time). When everyone told me tilbrooks was so expensive i didn't expect to pay less for sumfn like that compared to AMMR, haven't been back.
@ danny - i got a EBC (greddy B spec) on layby atm, ill put it on b4 i go c jeff, that came up in conversation when i was talking to him on the phone.
AMMRR not cool hey? well thats a bit disturbing, they are nice blocks down there and close to home :D
so Rubzy and leeman. who is your mechanic now?
*edit - leet spelling*
Edited by joeleo87
AMMRR not cool hey? well thats a bit disturbing, they are nice blocks down there and close to home :)
hehe layby is so cute :laugh: good work bud, ive heard good things bout boostinOz they on the side street near pickels auctions i think :)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
