all mate motor repair i think hes across from the parafield airport go down the service road after the car yard keep going till u get to the water bed shop turn there and go down to the end on the right should be in phone book if u cant find
  • Replies 67
140 is about right with std boost on a stock turbo. :S
Stock turbo mine it felt slow. No real urge through the mid range.
Mine made 152rwkw on 12psi stock ecu, 3" exhaust.
Tuned ecu they make around 170rwkw with 14psi or so.
Once i got 15psi in to it it transformed the car; gave it heaps more mid range. Drove it like that for 100,000km's ~3years until I finished building the new motor.
As for mine. rb30det (r32 rb25de head) with all the standard bits + a gt30r on the std exhaust manifold. Same 3" exhaust.
no he probably put 15psi thru the stocker like i am until i finish building my RB30DET.
i made 150RWKW on 11 psi (stock boost) with my brand new 040. Before when the pump was leaning out, i was running 141RWKW same boost same every bit of hardware, just a different day.
so your power seems about right with a leaning out pump.
u got 15 psi out of a high flow 33 turbo? couldnt b the 32 turbs.
A stock rb20det turbo.
The stock rb20det turbo's @ 1bar on a 'street' r32 rb20det is perfectly fine providing its not leaning out or detonating.
If its doing either kiss the turbo good bye.. Ensuring the tune is good is the key to longevity.
i rly wanna see how much i can get out of the RB20, you never see RB20's in mags or nothing always 26s,25, sr20s etc etc.. so im not sure how to go about it.
i think ill go talk to jeff b4 every1 gives me a beat down :P
haha good boy.. the rb20 is good but its just alot smart to go rb25 for more power, the rb20 doesnt have the torque to start spooling bigger turbs! pretty sure the old yellow onevia from jms was running 280rwkw+ with rb20! your most prob better gettin the rempa then save for 25 conversion, it also good because jeff is now remapping 25's yay!!
haha good boy.. the rb20 is good but its just alot smart to go rb25 for more power, the rb20 doesnt have the torque to start spooling bigger turbs!...
god damn it i was afraid some1 was gonna say that..... how much do the conversions go for these days?
Im putting a Trust TD06 20G 8cm turbo on my car in a week or two, removing the RB25S2 turbo, Expecting to see a full 1.2 - 1.4 bar by say 4000 rpm or so. And Ill be using a 8500 rev limit which I wouldnt be comfortable using on a 25. 4000rpm to 8500 is a pretty wide powerband to be using at full boost. Hoping to make a solid and reliable 250 odd rwkw's.
Will be changing to a RB26 6 throttle plenum as well, and possibly tomeii poncams down the track to gain even more response should I need it.
Sure, Could have gone to an RB25, but my engine has only done 50 - 60,000 kms, even comp across the board, leakdown test good, besides, it's all ready in the car, and top top it all off, a 20 costs half to a 3rd of the price to replace if I should pop it.
Nothing wrong with a 25 by any means, just Im a hardcore fan of the 20, and it made much more sense to me to keep the 20.
Im also upgrading to a RB25/Z32 gearbox with a twin plate, and a single piece tailshaft, hoping to have pretty much a bulletproof driveline, which is a good thing to have in a drift car.
Nothing wrong with keeping the 20 in it, pop it and go to an RB25DE, and bolt all your 20 gear to it and still keep the costs down.
I guess it all comes down to what you want out of the car and how much you're willing to spend.
Edited by R31 drift pig
Nope.
Getting an adaptor plate made. Waiting for costing as we speak.
Otherwise Ill be going for a Custom made BTR plenum, or a RIPS bolt on job.
Yeah, it makes the bay look a shitload neater, but Im also hoping cutting 3.5 foot of pipework out will help with response. Also makes plug changing/servicing a shitload easier.
There are probably better things to spend your money on first though.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
