Item:Sony VGNSZ45 Laptop
Age: Used about 5 Times in 6 Months
Condition: Excellent
Price: $1500
Contact: Ben - 0419741040 or [email protected]
Comments: See Below
I bought this from Harvey Norman thinking i would need a laptop for university, turns out i really don't at all. Used it about 5 times total.
SPECS - Full Specs on website but ill list the main ones
Core 2 Duo 2.0Ghz
2048MB Ram
120GB Hard Disk
Dual Video setup (Stamina Mode uses Integrated, Speed mode uses Dedicated 64MB GeForce GO 7400)
13.3" Screen
CD / DVD Burner
Webcam with Integrated Mic
PC Express Slot
3 USB Ports
Memory Card Reader
Extras Include:
1GB Ram Upgrade (Total 2GB)
MS Office 2007 Home / Student
Trend Micro PC - Cillan Internet Security
Extended Warranty through any Harveys Stores until end 2009 or possibly 2010.
Machine is restored back to complete factory settings, software reinstalled and ready to go. Computer is great for work / uni, light weight and has a battery life up to 5.5 Hours on standard battery. Vaio's are regarded by most as the best laptop computers available (one of the few constructed in Japan not china) I paid over $3000 for the machine and upgrades (Thats at staff rates through Harveys also) and have receipts so come grab a bargain! I will also swap for parts to suit Skyline R34 GTR so PM me about that.
Full Specs Here - Full Specs / Pics Here - NOTE - You must select machine 4th down on the right
post-4555-1205420404_thumb.jpg post-4555-1205420463_thumb.jpg post-4555-1205420509_thumb.jpg
Edited by Got Boost?
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
