If it's untouched with over 100,000k's will probably mean you'll have to spend some money on it sooner or later, so a recent rebuilt one would be OK with rebuilt turbos as well (they don't last forever).
As for K's who knows? It's hard enough to know if the k's on the clock are real or not anyway, most imported R32 GTR's here have had a cluster change. If you can find a GTR with books and original cluster would be the best but good luck with imports as the books are hardly ever there.
https://www.sau.com.au/forums/topic/208350-rebuilt-gtr/#findComment-3686815
Hey guys...because i am going to purchase a R32 GTR soon...but not too sure...would it be better to get a rebuilt engine GTR or ones that has been untouched?
Also how many Ks...would be consider average for a 93-94 R32 GTR
thanks!
It's wise to be patient and get the right one. Even if it took you a year to find it, you'll never regret it Taizi.
One thing you can do is ask the owner for past paper work and diguise the fact that you're after pink slips as well. Funny, I keep all mine over the years and one thing you look for is the current mileage on the pink slip. If from one year to the next, the mileage has dropped, you have to suspect either tampering or a new gauge cluster has been installed. Any detailer or panelbeater will also tell you that bolster/carpet/steering wheel wear is a giveaway marker.
And lastly, take the car before the deposit, to a Skyline specialist workshop for a detailed look and be prepared to pay for this check. Well worth the trouble.
Regards,
Terry
https://www.sau.com.au/forums/topic/208350-rebuilt-gtr/#findComment-3687519
Go the rebuilt one, make sure it's been done properly though this means confirmation of parts and work.
Need less to say you'll hear it from everyone, the amount of money you will save buying one with all the work done to it is ludacris... There is an abundance of them for sale atm and the demand is low, owners having to negotiate to shift there cars.
https://www.sau.com.au/forums/topic/208350-rebuilt-gtr/#findComment-3703183
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
