Installed a dual stage boost controller (turbosmart)c On my RB20 Now the car sounds like it's not runnng on all cyclinders, or has a bad boost leak.. then stalls. This is just at ide, the way i have it set up is. the hose flowing from intercooler nipple to wastegate (obviously with the bleede valve in the middle. arrow pointing towards the wategate. I plugged up the nipple on the comp housing with a screw.. anyway. so i hooked it back up to the comp housing ranther than the intercooler pipe and still the same..
--IT WAS THE INTAKE PIPE THAT CONNECTS TO COMPRESSOR, HAD CAME OFF A BIT--
thanks for the help, kept me looking.
Edited by ClintR33
https://www.sau.com.au/forums/topic/208377-boost-controller-question/
Hmm, i returned it to facrtory and still the same. Somtimes, i wish it could just be simple.. and work. It worked on my 33 fine. Still die's at idle, and runs rough as. I took the plug to the AFM off when i put the boost controller on so i thought t could be that, but it's on there good...
So nobody has any idea? it's back to stock, checked all the hoses and wires.. all fine, the only thing i can think of. I drilled and tapped a hole in the crossover pipe, maybe a bit of shit got into the motor. (alloy shavings) but could this effect anything? It's running rough, hardley idles and smells like its running rich.
Are you certain that none of the cooler pipes have blown off?
LOL, f*kn weird isnt it? im a verry DIY person but this has got me stuffed.. i took it for a trash 1hr before i hooked up the boost controller and it ran fine, then put it on.. ran like shit.. chucked it back to standerd.. still shit! changed the AFM.. still shit... i dnt know! all intercooler pipes are fine. on another note, i'm pretty sure the 20 doesnt have a boost soinoid like the 25, cause the hose runs straight from the vacume nipple on the comp housing to the wastegate actuator.
i dont like the sound of this
was the pipe off the motor when you drillied into it?
I'd be checking the plugs and checking to see if maybe one of the tips has been damaged by some alloy debris.
that would be the first thing i'd do. if some alloy has worked ints way into the cyclinder i'd look for that before you try to fire it up again. that corss over pipe has a thick sidewall so there would be a few shavings flaoting around.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
