Scooby Posted March 1, 2008 Share Posted March 1, 2008 I'm trying to get away without a catch can, at least in the short term. These aren't going to be as good but could still be quite effective. Does anyone know if they are better than the mesh baffle already in the RB26 cam cover? ? http://hioctaneracing.com.au/eshop/product...products_id=503 Cheers Link to comment https://www.sau.com.au/forums/topic/208405-mines-cam-cover-baffles-rb26/ Share on other sites More sharing options...
noone Posted March 1, 2008 Share Posted March 1, 2008 Was wondering about this too brought a set for my 32GTR only to have my tuner say he couldnt fit em?? He hadnt seen em before though so wasnt sure any one know if ther is some trick to fitting them Might have a go myself at a later date I would still recommend running a catch can though! Link to comment https://www.sau.com.au/forums/topic/208405-mines-cam-cover-baffles-rb26/#findComment-3687597 Share on other sites More sharing options...
bnr#@ Posted March 1, 2008 Share Posted March 1, 2008 (edited) Have fitter mine, don’t know how effective they are as the engine isn’t running yet... Yes there sort of is a trick to fitting them, the little baffles that are bolted to the things that hold the cam I place about in the middle of the head need to be moved to the back of, as in they need to be bolted to the last thing that holds the cams... hard to explain really... ... If you go here : http://www.mines-wave.com/ Then click on "english page" then "power managements" then under engine parts click on "triple flow cam cover baffle" it has a couple of pix that may help but nothing about moving the old baffles back... Edited March 1, 2008 by bnr#@ Link to comment https://www.sau.com.au/forums/topic/208405-mines-cam-cover-baffles-rb26/#findComment-3687623 Share on other sites More sharing options...
Scooby Posted March 1, 2008 Author Share Posted March 1, 2008 thanks mate thats a good tip. the link says "Mine's Triple Flow Cam Cover Baffle Plate always separates the gas from the oil by adopting three-layer structure that forms the gas / oil separator". Sounds promising. Cheers Link to comment https://www.sau.com.au/forums/topic/208405-mines-cam-cover-baffles-rb26/#findComment-3687857 Share on other sites More sharing options...
