Item: R33 RB25DET Turbo Back Exhaust
Age: I'm not sure, probably 2 years old.
Condition: Good condition. No holes, or rust
Price: $600
To Fit: R33 RB25DET
Comments: This exhaust is off my old RB25DET engine, when I put the RB30DET in, I have had a completely custom built exhaust made up, as such, this will bolt COMPLETELY into your car. No worries. It is a full turbo back exhaust, and has passed noise level tests on my car (Rated at 88/89DBa) has a very nice deep note. Cat, 4" hotdog mid muffler, Oval stainless steel rear muffler with twin tips.
Item: R33 RB25DET motor
Age: 14 Y/O
Condition: Has issues. Blows alot of smoke, probably wants a rebuild. Minimum it might just be a BHG, but it is also lacking compression on cyl 3 (70PSi) all other cylinders were at ~150PSi
Price: $1000
To Fit: R33 Series 1
Comments:Motor comes with every thing except for: Engine mounts, oil/coolant heat transfer, coil packs, ignition box that sits on top of coil packs, power steer pump or bracket, alternator, starter, flywheel, air conditioner, fan. Needs new harmonic balancer too.
The turbo will be sold with this motor. Or I may seperate.
Contact: 0406 962 347. Please SMS me, as most of the time I have very poor reception, or I'm at work/uni (Which I generall have bad reception at) I will reply to SMS immediately, or I will call you as soon as I have a chance to. You may also PM me, but phone is by far quickest.
Edited by MBS206
any chance of separating the turbo water and oil lines, feed and return lines, banjo bolts?? if not, how much for the turbo plus all above mentioned things???
Sorry to all, I've been away from the PC a bit, and away from my phone for a bit, but I'm back now, and I do have EVERYTHING except the injectors.
My messenger now has room in it again too, so you can PM me again.
The motor and exhaust are still here...
Make an offer people!
At the moment the turbo and motor are seperated, but both still here.
Make offers on either!
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
