I am thinking a turbo has totally lunched itself.Engine oil seems normal and it isnt running hot...So I would assume the head gasket to be healthy still..But gutless and water leaking...This is turbo.Water is leaking into the inlet from the turbo...thats why you got it at the BOV..Also explains why its getting to the exhaust.Now if for arguments sake headgasket was gone it would also cause similar symptoms...However I think it would be overheating within minutes and your oil would be looking like choco milkshake.So the problem seems to be isolated on the turbo side of things..I am thinking one of your turbos survived and the other is dead...Thats why you got some boost there and also why its slow to respond...Maybe I am wrong...but definately worth inspecting
disconnect both turbos from the air filter pipe and the boost pipes and check the turbos.
Check that the inlet pipes do not have any oil or milky oil.
If they are 100% clean then id go see a mechanic to be sure, do a leakdown test and compression test as well
In the meantime do not drive the thing...If you got water coming through the BOV then there is a pretty fair chance you gonna get a water build up in the intercooler also..It will come on boost,pressurise the water built up in the intercooler into the engine and BANG ! Conrod hanging out the side of the block
Maybe try disconnecting the wiring to fuel injectors (so it wont start) and turning it over and listen to see if it sounds normal. If compression is low in one or more cylinders due to blown head gasket it won't turn over at a constant speed...it will speed up when on compression stroke of bad cylinder..
Certainly not a subtitute for comp and leak down test but very easy to do and will indicate major comp loss...
Hey Cheers guys for this info hey! Certainly Opens up for some suggestions to ask a mechanic about it! Just i gotta find a good mechanic now in Townsville as i have only been here for 6 months and the car hasn't been in a shop here yet!!
With all this stuff that could be wrong with it, all i can see is $$$$ Symbols and bank account going down! Maybe i should lash out and get NEW Turbos!
did u get past 0 mark on boost gauge at all.. if one of the turbos let go, you will only make it to around 0 mark.. also someone on here mentioned if one of the rear wheels on the turbo is blown, u can check if it placing your hand over the air filter inlet pipes.. think the blown one will blow air rather than suck.. maybe someone can clarify..
Right i started it this afternoon and let it run for about 20 mins. Was checking if it overheated but went well. Stabbed the accelerator for a bit and saw less smoke then 3 days ago. There seems to be a little more watery stuff coming out of the exhaust at this stage but this could be condensation yeah???
My turbo gauge on the center console is running halfway between 7 and below the 0. Is this the normal operating?? When i Rev it it goes up to 0. I really haven't seen it go past the Zero that much! Does it go past the 0??? I have a Boost Gauge in the car on the pillar but it doesn't seem to work anymore cause the gauge just sits like minus 400 or whatever it is! The light to turn it on still works!!! lol!. Could it be electric Problems as there is a little valve or solenoid in the Engine bay which it is connected up to???
Oh and another question. What does the PCV?PCM? Valve do near the Battery in a 32 GTR????. I remember one day taking a small cup and small bearing out of the rubber lines years ago as i heard it did something better! But unaware if it really did make any difference??? So it has been running like that with out the little Bearing and Cup thingy for years now.
  • 1 month later...
the pcv valve is located mid engine..pollution control valve on the left side if looking in front of it...could be inlet leak??
my GTR does the same...when warming up...water/exhaust crap..come out of the exhaust....think thats condensation n pretty normal.
But yeh prob do comp n leak down test to make sure.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
