hey everyone, i did a search and couldn't find a topic in here that specifically recommended importers (link me if i did a dud search)
what importers would you recommend? (its in you're best interests to keep it clean as its against the rules to sledge companies on here.. .. .)
- what car did you buy
- when did you import
- what company did you buy it from
- testimonials?
- customer service (eg friendlyness, helpfulness, description of the car etc) ?
- time frame (how long it took)?
- satisfaction?
- umm, anything else? just stuff like that :)
;):P
Edited by Brycey
https://www.sau.com.au/forums/topic/208454-recommended-importers/
Get onto Mark Hocking. I can PM you a mobile number if you want.
Autech 260RS
Importing currently (arrives 15th march)
www.mytrading.org is Mark Hockings company
Was recommended by a few others (go to 'importing a vehicle)
I spoke to mark initially about a month ago. Time frame will depend on what car you want him to find, mine was a fluke. BUT as far as time frames they can CONTROL go, it was on the first boat, no delays with paperwork or communication.
Very satisfied so far. Right car at right price, just waiting to see the vehicle! (auction grade 4) so it should be pretty good.
Rob
sounds like you have had a smooth ride :P i dont really know many import companies (just the main ones like j-spec - who did mine, prestige autos, those sorts) so yeah, just looking to educate myself on the best options for in the future and anyone else looking around :)
1997 Stagea Dayz RSfourV
~4 months ago
J-Spec
Professional, sometimes (mainly pre-purchase) slow with email responses
Took about 12 weeks from purchase to my door.... took abit longer cos compliance workshop was waiting forr DOTARS to send back paperwork for ~3 weeks.
J-Spec sent me about 200 detailed photo's.... car was as described, and I was very happy with it. Only needed tierod ends for blue slip, which was great considering it was the cheapest Stagea on the site at the time.
All correspondence was by email... never spoke to anyone but the shipping company in person (KIWI by the way, and I was more than happy with them), which was a bit worrying at the time, but it all worked out well.
Exactly the same as above, but for JZX100 Toyota Chaser
Also, have just bought a Mitsubishi Legnum through them 3 weeks ago, which is yet to board a boat (booked for 10 march), and have had no further email delays. I would not have purchased a second car (before I even received the first!) if I weren't very impressed with their service.
I have a friend who used www.directimported.com many times, and is more than impressed with them, also.
Does this thread only relate to stageas?
- what car did you buy 1998 R33 40th Anniversary
- when did you import Mid 2007
- what company did you buy it from Elite Auto Imports - local Adelaide guy for those wanting to import and is from Adelaide - He has a section on http://www.rpmlounge.com.au/forums/
- testimonials? highly recommended it was my first time importing wasnt 100% sure at times but importing through him has definitely built my confidence in importing cars and I will definitely import again via David @ Elite Auto Imports
- customer service (eg friendlyness, helpfulness, description of the car etc) ? friendly, very helpful getting my car from the docks to my house then to the compliance workshop - car arrived better than what was described on the auction sheet!
- time frame (how long it took)? about 3 months? it landed Friday picked up Monday - super quick was nice, was my favourite part of the whole importing process having the car landed finally and can take it home, I've heard of people having to wait for ages while their car was at the docks... I got mine the following business day!
- satisfaction? 10/10
- umm, anything else? just stuff like that I love this car :down:
Edited by vietorious
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
