Thermo Fans, How Much Is To Much...
4drftn
 Share
im thinking about removing my engine fan and putting twin thermo's, what size is recommended?
i was considering putting two 12" thermo's in front of engine (push type) and because my intercooler, covers my radiator (stopping airflow) a push type on the front of the radiator aswell.
would the alternator handle it? am i going overboard with having one on the radiator too?
what are you using?
cheers
ford thermo fans pulling... would it be better to have push towards the motor aswell?
G`DAY 4drftn have a look at nissan maxima vg 30 they have twin thermo`s straight fix should pick them up for $100 if your luckie try & grab the connector`s as well,good luck dude,cheer`s chuckie
  • 1 month later...
I wish i still could keep the stock clutch fan, but it doesn't fit in my engine bay. Don't go thermo fans, they're shiet.
Too bloody right.
See how long the alternator/battery last running 2-thermos, lights etc. Mine does not like it at all.
First item to melt was the lug on the alternator's output cable, simply not designed for that large constant amperage drain.
Stock engine driven fan FTW. (if you can fit it in)
 Share
