The car is actually a jzx100 chaser. When I picked it up it still had jap spec fuel. I filled it up with 98ron and now im home (the sticks) I have to use 95ron.
Its gotten worse as the fuel got worse.
Could this be a problem?
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3688985
dave when i picked my car up from compliance it was set at 0 degrees base timing
they mite do this because of the high ron fuel over in jap and then wen some young dickhead hopes in the skyline puts in unleaded thrashes it and it doesnt detonate lol
15 degrees advanced ftw lol hmmm i rkn check timing first aye
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3689495
what gap are your plugs dave?
i remember when my stock coilpacks were stuffed, so i gapped mine down to around .6 to stop the miss fire on boost
i noticed with the really small gap on idle it would sit there miss firing its ass off, but drove fine under load not miss firing
i then tried another set i had there which were 1.1 gap and it stoped the miss on idle but yeh spark would blow out from crappy coils lol
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3690346
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
