hey boyz i have just finnised building a 30/26 block was cryod crank cryod and nitried grub screwed and all the rest of it i used 22mm pin argos i beam and got som custom 9:5-1 je pistons made the head was done by rams in sydney ported os valves high lift springs titanium retainers etc i use hks 272 10.2 in 280 10.2 ex turbos are twin hks 3037s and i used a hypertune plenum single t/b its a street car that i may drag race if lag is a problem nitrous will fix that hope to make around 700 hp atw well soon see
I hope the build is better then your grammar. I'm not fussy on spelling, but please just break it up a little to make it easy to read, it is better for everyone.
  • 3 weeks later...
i got a rb25/30 NEO in workshop atm geting build. Im using jun oil pump with hi-energy pro sump (8lt). Using t04z and tomie poncams 260. Aiming for 650rwhp. These were the biggest the NEO head can take beacuse of their desgin. They shouldnt be restrictive? I also have a wet nos kit and goal of 700rwhp once armed. Using argo rods aswell. I wouldnt use spool rods with 800rwhp
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
