Hey guys,
I saw skykc's cai pod thread and liked his ideas, so gave it a crack myself. I believe it is has been very useful and my pod has been keept at a maximum of marginal warm instead of boiling hot, even without a heatsheild, which I am yet to make. I have also noticed that the car is alot more responsive now regardless of the weather.
The whole amount of the hardware you need only costs around $30 if you go to the right places.
I used:
$8- 90 degree intake pipe from a vn commodore in Pick Pay n Go
$4- flexible black funnel from Bunnings
$12- 6 pack hole saw bits up to 100mm from Bunnings (were meant for wood but they were so cheap and I only wanted to use them once)
$3- Rubber edge to cover up the bare hole from Clark Rubber-"Cool Clarky" if you please :P
All up = $27
The whole process only took me about an hour and you only need very basic tools.
Tools required:
Hack saw
Drill
Wire cutters/Tin snips
Maybe a flathead or phillips head to undo a few plastic screws on the underbody
The Steps:
1. Once you have found a Vn Commodore intake pipe, you will notice one side is longer then the other. I ended up cutting it down to about the same, so I could fit the funnel on it and just fit it all into the front bar.
2. Once the pipe can fit in under the front bar (keep testing to find the right size) you need to cut the funnel down to attach it onto the pipe. The funnel is used to attract more air in the direction of the pipe to flow straight to the pod. It probably isn't 100% neccesary, but for $4 who cares?
3. Use the hack saw again, cutting the funnel about halfway through, possibly with a little bias either way. The next step you want to do is measure how much you need to flare the inside of the funnel so it fits snuggly over the pipe. At the moment, the smallest part of the funnel should be able to fit inside the pipe, fit it in and see how much you need to flare the funnel.(It should be about a centimeter)
4. To flare the funnel you will probably need to make about 10 tabs with the hack saw around the smallest end of the funnel, each about 1cm deep. Once the tabs are made, grab a lighter and make the tabs just a tad warm which will make it a little easier to bend the flares with your fingers. The final result should make the small end look like a flower, which will then allow for the pipe to fit in.
To hold the pipe and the funnel together, use an adjustable hose clamp to tighten down the open flares over the pipe.
At this point your piping is now complete, it is optional if you want to use some fly wire to stop any bugs/leaves going up the pipe to your pod, I was not to worried about this because my pod is already a filter so I don't think it matters. You now need to make the hole in your engine bay.
5. Get your pack of hole saw bits, I used a 90mm size which fit very snug. Adjust where you want to place your hole, I decided to make it right in the middle under the pod. Attach the hole saw to your drill and start off very slowly. (From what other people had said I was weary of using hole saw bits that were made for wood, but they were a quater of the price of metal ones and I only planned to use them once.) After you have made the rough outline of where you want your hole start pushing down a little harder, then just keep holding it there, that way the teeth on the hole saw bit wont go blunt as quickly. I did it this way and it took me about 2 minutes before I could simply peal off the perfect circle like a metal can lid, plus I still have plenty use out of the hole
saw!
6. Once your hole is made you need to put the rubber edge on, and if you have it handy, spray some fish oil to stop rust(if you don't, don't stress, the rubber edge stays on nice and tight!) To get rubber the right length slowly cut it down in educated guesses, because it slips in deeper to the edge then you think and you end up needing more or have a part where the circle is not complete. I strongly recommend you use this rubber edging because it makes the hole look a lot more professional and hides any imperfections you may have made making the hole. ( in the pics the circle looks a little lop sided because the rubber had not been put on properly yet)
7. The final step to do is adjust the angle of the pipe a little, just so the funnel is pointed right in the center of the hole of the front bar and try to point the 90 degree pipe slightly down so dirt and water can't fly up as easily. I simply used a few hidden cable ties and found a few holes off which to angle them by.
Hope you all enjoyed and also check out my heatsheild tutorial!
  • Replies 44
  • 7 months later...
hey guys,
it was hard finding a pipe to suit well, especially because I did take into consideration stuff like driving when raining and the high pressure hose....
to overcome any water getting up there I adjusted the angle of the piping slightly, just so it faces downward a tad more... that way when any water decides to go up it, it runs back down. ... I also dont shove a hose up there ! ;)
I don't know exactly how it would work with other cars.... am always happy to offer ideas if u send me some pics of the engine bay, but I have only done it to my car :(
theres no reason it couldnt work though, because you customise the piping or the location of the hole(if neccesary) to under your pod.
Regards,
Adam
with a stock pipe you mean using the standard panel filter setup and snorkel? or with the standard side mount still there?
perhaps send me a pic of your setup?
I thought about putting the pod lower where the cai starts and not having to worry about a heatsheild and it can be done. but bear this in mind:
-its very close to the ground, driving in the wet could cause big problems
-you will have to change it almost weekly depending on how much you drive
-There would be problems with the afm aswell if you wanted to keep it directly behind the air filter, ie you would have to extend the loom so that it could reach behind the pod, make a custom pipe to keep it where it is and include it in the induction system.
-because it would be that low and practically exposed to the elements except for a pod infront of it, it could fail pretty soon, causing your ecu hell!
so I choose my setup instead :P
Blitz LM Kit, uses the stock pipes, so both holes are still filled with pipe :spank:
If going down the CAI route, id leave the AFM where it is. Unsure if it effects it being further from the filter tho. Wouldnt imagine so.
I had CAI's on my Hondas with the filter in the bumper and never had issues. The filters are infact waterproof, you just dont want to submerge them. Rain doesnt hurt. All you do is take it easy in the wet, and watch for "surface" water that ends up being 2 feet deep :)
Afm does not matter if it is directly behind the pod/standard intake or near the throttle body, aslong as it can measure the amount of air going into the engine.
I know this because when I got my new big turbo, it obveously was doing its job blowing air hard into the system, but it also forced a small amount of air to go back the other way, which gave the afm a negative reading, the way around this is to relocate the afm :domokun:
And yeh... with melbs weather + pot holes... just gotta look out for the deep ones filled with water if your pod is right at the bottom of the bumper :P
Adam
Sik!
Ive actually done a similar idea...
I used to own a VT LS1 powered commodore and I upgraded my intake pipe, so the stock one now is on my skyline!
Same place - but I didnt even think of using the funnel as the entry at front bar - Thats what Im gonna do on my lunch break, go to bunnings! hahah
This is the airbox I made last weekend, so with the cold air pipe and this, it *should* work ok! haha
airbox.doc
just to add with the pod filter sitting infront of the bar it can be done and you will not have to change you filter almost every week if you get the right pod
it will be a bit of a pain making a pipe to keep the afm safe in the engine bay (you really dont wanna get this wet) then run the pipe to the front of the bar and use a pod filter thats been coated with oil (k&n filters are coated in a thin oil film) which will help water bead of it if it gets wet. just dont drive through a puddle
have done it to a GTR32 before and it was a massive pain in the ass for the GTR but shouldnt be much of a pain for a GTST but just a warning the induction is seriously loud as its exposed and the sound wont be quitened by the closed bonnet
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
