Hi guys,
Just ordered a HKS GT2835 Pro S from Greenline for my R33 GTS-T and I was wondering what sort of torque figure I should be expecting with it.
Yes I've done a search, and looked in the dyno threads and I couldn't find any info regarding torque output. Here are my mods (well, will be in about 2 weeks time):
GReddy Front mount I/C
SplitFire Coil Packs
Power FC
Straight through 3.5 inch exhaust
Pod filter with custom Cold air intake
Bosch 040 Fuel pump
Nismo 555cc Injectors
HKS GT2835 Pro S Turbo
Z32 AFM
Running 17 PSI
I know I should see about 250 - 260 KW at the rear wheels by looking at the RB25 dyno threads, but what about torque output?
I am sure most of you know that torque wins races, not kw. So, any ideas?? Has anyone with a HKS GT2835 Pro S actually had their torque measured?
Hoo roo
Cool thanks..
Not too happy but, I found out that a 2008 Holden CLubsport has 550nm of torque at 4400 rpm, the graph in the link you sent only has about 520 nm at its max.
Does this mean that a standard clubbie would beat a GTS-T with a HKS gt2835 pro s?
a well setup GTST will take down a new clubsport no problems
lots of things come into play when going against another car
diff gears also play a big part - you'll be fine
i was able to take down a 2000 ish model R8 297kw ute with my 200rwkw and stock turbo and well setup GTST
the specs are here http://www.highperformancetrucks.com/truck..._view.php?id=48
They say there that the 0 - 100 km/h time is 5.1 secs for the maloo ute, would a skyline with my above mods be quicker than that?
cheers
yeah should be - i managed 0 to 100 in 4.88 in my gtst with a perfect launch and good tyres
that was with the rev speed meter and g sensor kit so it should be reasonably accurate ish
your reading too much into specs and numbers on paper dude
dont stress the car will be very fast on the street
even with the std turbo and a good setup the gtst is a pretty quick car
Yeh, trying not to stress, but when you spending thousands of dollars (nearly 12K I've spent now with the mods I have) you want your car to be quick as a rocket and have power outputs to come with it.
When I got my car dynoed the first time (pulled out 202 rwkw with standard turbo and PFC) the tunner told me its not about KW, its about torque. Now I know the new clubsports are a fair bit heavier than an r33 GTS-T, but their torque is crazy, 550nm at 4400 rpm!
I noticed that link above with the dyno sheet by sly33 managed to get like 280 rwkw but only like 520 nm of torque, does this mean that a new clubbie would beat a GTS-T with a HKS GT2835 Pro s sicne it has more torque?
WHen you measured that 4.88 0 - 100, was that with the standard turbz?
With the mod list you have and a good tune believe me you will slaughter a hsv. You turbo choice is damn good for a quick response streeter. My bud has a very similar setup and runs low 12's on the strip. More than enough to take care of most of the v8's you will encounter.
as i said stop reading into the figures and just drive the car when its done
be sure you have your suspension sorted out otherwise youll struggle for traction
yeah my 0 to 100 was with the stock turbo
Of course they're going to make more torque... They're a 6L V8 after all. :D
Think of it this way though. They have 297kW, you will have 325ish. (Flywheel) They weigh 1800kg, yours weighs 1370kg...
Yes but I weigh 120 kgs.... lol
So you're saying, even though they have more torque, I will still be able to beat them merely because or the weight of my car (being less)?
as i said before - lateral acceleration and weight is the main factor here
dont read too much info magazine plotted numbers and graphs etc.
the gtst will run 4.11 diff gears and weight less - so it has more rapid acceleration
the r8 or whatever probably has taller diff gears (3.7 ish) so less acceleration, more top speed and weighs more
so on the dyno plots it looks the same or stronger but on the its a different story
look into a diff cradle kit to stop axle tramp
look into some better tyres
but try it once the turbo is fitted and tune is done etc
then see if you need more traction etc- i bet you will
I've noticed the insides of the rear tyres are wearing out heaps (probably about the inner 15%)
So, what tyre size should I get, 235?
WOuld it matter if I got 235 on the back and 225 on the front?
go see a suspension place about the tyre wear
you need some camber to align it properly
youll need a diff cradle kit to stop axle tramp too
some bushes will probably help with handling too
most mild gtst's go for 255's on the rear
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
