I got my r33 in june of last year, thought it was working sweet after getting it checked by a emchanic before buying it. Seems like it was the biggets mistake of my life because it just doesnt run properly and everything i do ends up solving one problem but creating another. Nothing has gone my way with this car i must be cursed or something.
For reference the car is a 1996 s2 r33 gtst. Only mods are apexi pod and just recently a trust pe2 catback.
Yesterday a mate and I adjusted 2 exhaust hangers to get the exhaust sitting in a better position since the lip on the mid muffler was hitting the tailshaft (not often at all, but often enough to warrant the adjustment).
Anyway after doing that we took it for a test drive and it was fine, i got back to my house and i started to hear a very high pitched whine, kinda quiet but noticeable. The car then started running "lumpy". For lack of a better term, ill just say it kinda sounds like a rexy when i rev it a little. Not good at all. The car shakes, feels and sounds really lumpy.
We then checked the plugs (which are like 4-5months old), regapped them to 0.8 from the previous 1.1mm because it was popping alot but nothing changed. Still sounds rough.
I REALLY wanted to do everything myself or with a mate to save money cant afford a good workshop right now. However if i or anyone else cant work it out i may just have to save a little and get it checked out.
Any ideas?
Edited by delljit
https://www.sau.com.au/forums/topic/208516-help-my-skyline-sounds-like-a-rexy/
everything should be plugged in properly, the coilpacks looked fine too (no cracks etc)
we also didnt touch the coils/plugs until after the problem started, is it just a oincidence that it may have decided to shit itself then?
check for leaks,
mine had a leak between the engine and exhaust manifold cause the manifold bent. Sounded like a v8 haha, and shook etc.
And also ya said it ran sweet and only thing that you have done recently is exhaust.
So check around ya exhaust manifold, turbo, intercooler pipes, dump exhaust etc.
Make sure all bolts are tight and havent come loose.
I also had a fun time recently my plenum warped, so i know how it runs when theres a leak there too haha. #$%$#
check for leaks,
If thats the case i dont think i can check anything out myself.
Would i be doing any damage if i drove it to a workshop?
One last thing, when we took the plugs out they were black as a motherbollockser, im using ngk iridiums. Carefully cleaned them before regapping to .8 and putting them back in. Car still pops though.
you would be able to check all the bolts yourself on exhaust, turbo, intercooler pipes etc. not hard.
if it is an air leak, wouldnt suprise me that your spark plugs are clogged with shit if its running rich.
Also check ya oxygen sensor. I remember my plugs were screwed from running rich, and oxygen sensor wasnt working.
I could be way off from what the issue is, but there is no harm in checking those things first.
if its a exhaust leak, most likely its on the bottom back half like u did with the cat back.
jack the car up, and look under there. start the car up, and have a smell, and check for visual leaks.
then feel your way around the flanges to check for leaks. odds are that u have broken a sealed gasket when u twisted the exhaust.. no big deal.
finally. start the car, pop the bonnet and listen, if there is no loud exhaust noise u have not broken the seals in the bay... then check the rest of the exhaust underneath.. if it is louder than the noise from the muffler=exhaust leak
i fail to see how it could be anything else if u have only touched the exhaust!!
i checked for exhaust leaks with soapy water on the flanges under the car, everything seems airtight. guess im just gonna have to savea couple pay checks and take it somewhere good, im not really the mechanic-type as much as i'd like to be.
To check for exhaust leaks, whilst you're under the car, get a mate to completely block the exhaust tip or tips (unsure if you have more then one)
If the car is cold, he'll manage to do it with his hand. but most of the time, use a rag.
You'll then hear the leaks ALOT clearer.
When I blew my flange between cat and dump pipe apart it sounded like a tractor... A quick tighten and a heap of exhaust cement, and it was perfect.
By twisting the exhaust, you've most likely broken an exhaust seal/gasket. It's easy to do, nothing major to worry about, just fix it now.
On a small leak I had, I also had the V8 sound as it wasn't a large leak.
if it sounds like a rexy then its not running on 6 cyl.
I would disconnect one coil pack at a time while its running and when you do if the car feels like it runs rougher when its unplugged then that coil pack is OK.
if you disconnect one and the engine does not change the way it runs at all then thats the cyl that your having the problem with.
Take that coil pack out and swap it with another cyl and then start the car and unplug the cyl that you put the coil pack into, if there is no change again then you know you have a dud coil pack.
I have some series 2 coil packs that i can sell if your interested.
ill give that a go after uni today in the arvo
so i basically have to do the following:
remove the pipes that are in the way
undo and remove the black cover
re-connect all the pipes
start car
disconnect 1 coil at a time, listening for a change in engine sound
if i find one that makes no change in engine sound, stop the car, swap it with another coil and see if the new cylinder is failing?
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
