I got hold of some M-type front brake for my 32. but i just got the calipers and rotors and a few fitting that go with it....
this is from http://www.skylinesaustralia.com/forums/R3...ml&hl=brake
To do conversion:
a) type-m 4pot caliper x 2
B) type-m brake lines and all fittings x 2 (mandatory!) <----------------------------------- ZOMG! My lines were cut!!!!!
c) type-m spec discs, which will generally be much thicker than the non type-m
d) brake fluid bottles x 2 (DOT 3 or better rating) - supercheap auto
e) brake bleed kit (supercheap auto)
"In a way this is one of the more fiddly parts of the process. Make sure you have the type-m lines or equivelent, as the non type-m have a different thread pattern on the caliper end and WILL NOT work (trust me I tried)"
So that means i need M Type lines from somewhere?
has any1 done this conversion b4, any help would b appreciated!
https://www.sau.com.au/forums/topic/208538-oh-noes/
Maybe try somewhere like Pirtek, I think they come out too but charge a call out fee or alternatively just take your parts in and see what they can do for you.
Failing that finding a wreck somewhere. Btw, what sort of $$$$ does it cost to upgrade just out of curiosity.
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3688537
ive got a set off R33 type-m brake lines from my s2 R33 4 door GTS25T type-m 1996 i upgraded to braided i can sell em too you how much you want to offer for them
P.S the 4 door brake lines are the same az 2 door upto ypou bud will the r33 lines type-m fit the r32 type-m brake calipers.?
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3689254
wat group buy section? is their a group buy thread on brake lines?
i was just thinking of taking it into my mechanic and getting him to fix it up. but id love to solve this problem @ home :S
Edited by joeleo87
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3691180
yeh thats just the lines... i cant find my effen camera atm. ill post some pics tomorrow. the calipers still have the 'm-spec' lines goin into them but they are cut further along the lines... so just past where the bracket sits, so i was thinking of just trying to undo the hose at 1 of the connection points and try and fit my hose in there.
*edit - Thanks for the link tho Evil, i need all the help i cant get :D*
Edited by joeleo87
https://www.sau.com.au/forums/topic/208538-oh-noes/#findComment-3691294
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
