hey,
everything is pretty much sorted. cooler piping, tailshaft, gearbox mount, bonnet shutting, rad, etc.
But am just a little unsure on a couple of pretty simple things.
1. have had the plenum refaced, with the throttle body at the front now. However throttle cable doesn't reach. Can it be extended, or do i have to get say a bigger Vl, r32, r33, or other cable.
2. Am not running a bov, so can i just get the rubber hoses which go the bov blocked off at the plenum. The black metal piping which leads to the bov on the turbo side have been taken care of.
3. With the new cooler piping there no place to plug in the vacume line for the wastegate. Can i just extend the line and get the reading off any part of the plenum, or is getting it off the cooler piping on the turbo side essential.
4. for the boost gauge reading, does that just get it off the plenum also.
5. for the vacume lines which go to the throttle body, now that at its at the front, is just getting a bigger line ok, will it effect the throttle body opening, and operating the way it should.
6. whats the best way to drain the fuel tank?
any help much appreciated. i will post some pics as soon as i can get a hold of a digi camera.
thanks again
jsut puta nipple in the cooler pipingand run the line from there
you might need a custom throttle cable
ps I want a ride when its done
boost gauge jsut off the plenum
also run into another problem.
power steering setup. The silvia has some some speed sensative unit. and theres 4 lines coming off that, yet theres only 2 spots on the rack.
And putting in new lines mite not be viable cost wise at this stage.
Just wonderding whether i could take out the power steering lines, pump, put fluid in the power steering rack, so it doesn't run dry, and block off the outlets and inlets, so no fluid can go in or out.
only worry would be whether the rack will suffer, or turning will be come impossible.
Anyone know what the go is.
Is it safe to do? or should i run new lines, but then if i bypass the speed sensative unit, it could cause problems up at high speeds, pretty tight for room with this one. and i got lines going everywhere.
thoughts on this please.
oh and i got the tank drained, hooked up old fuel pump ran it off a battery and pumped the old fuel out through some hose. worked well.
GTiR throttle cable fits on R33 with front facing plenum. I have been told you can get the stock cable modified as well.
Two spots on the steering rack? why not use an R33 steering pump? I think the R32 have like a dual pump with two lines for the rear hicas, and two for the front steering. If your pump has 4 outlets, do 2 of them run from a seperate resevoir? Sorry I dont have much of an idea what is exactly wrong with the power steer - but interested to hear what the problem/solution and outcome are?
Cheers
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
