hey,
everything is pretty much sorted. cooler piping, tailshaft, gearbox mount, bonnet shutting, rad, etc.
But am just a little unsure on a couple of pretty simple things.
1. have had the plenum refaced, with the throttle body at the front now. However throttle cable doesn't reach. Can it be extended, or do i have to get say a bigger Vl, r32, r33, or other cable.
2. Am not running a bov, so can i just get the rubber hoses which go the bov blocked off at the plenum. The black metal piping which leads to the bov on the turbo side have been taken care of.
3. With the new cooler piping there no place to plug in the vacume line for the wastegate. Can i just extend the line and get the reading off any part of the plenum, or is getting it off the cooler piping on the turbo side essential.
4. for the boost gauge reading, does that just get it off the plenum also.
5. for the vacume lines which go to the throttle body, now that at its at the front, is just getting a bigger line ok, will it effect the throttle body opening, and operating the way it should.
6. whats the best way to drain the fuel tank?
any help much appreciated. i will post some pics as soon as i can get a hold of a digi camera.
thanks again
jsut puta nipple in the cooler pipingand run the line from there
you might need a custom throttle cable
ps I want a ride when its done
boost gauge jsut off the plenum
also run into another problem.
power steering setup. The silvia has some some speed sensative unit. and theres 4 lines coming off that, yet theres only 2 spots on the rack.
And putting in new lines mite not be viable cost wise at this stage.
Just wonderding whether i could take out the power steering lines, pump, put fluid in the power steering rack, so it doesn't run dry, and block off the outlets and inlets, so no fluid can go in or out.
only worry would be whether the rack will suffer, or turning will be come impossible.
Anyone know what the go is.
Is it safe to do? or should i run new lines, but then if i bypass the speed sensative unit, it could cause problems up at high speeds, pretty tight for room with this one. and i got lines going everywhere.
thoughts on this please.
oh and i got the tank drained, hooked up old fuel pump ran it off a battery and pumped the old fuel out through some hose. worked well.
GTiR throttle cable fits on R33 with front facing plenum. I have been told you can get the stock cable modified as well.
Two spots on the steering rack? why not use an R33 steering pump? I think the R32 have like a dual pump with two lines for the rear hicas, and two for the front steering. If your pump has 4 outlets, do 2 of them run from a seperate resevoir? Sorry I dont have much of an idea what is exactly wrong with the power steer - but interested to hear what the problem/solution and outcome are?
Cheers
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
