hey guys im about to put my motor back into my r32 gtr,
i took the box and motor out together but i have to remove the steering rack to get it out,
is their a way to put them back into gether without taking the steering rack off??
iv heard if people putting the motor and box from underneath the car, im not exactly sure on how to do this.
thx guys
https://www.sau.com.au/forums/topic/208557-rb26-removal-with-box-attatched/
to put it in form underneath remove the whole subframe then put the motor and box onto it (do up engine mounts etc). they lower car back onto subframe, bolt subframe back into chasis and voila you are done
well we've tried every way we can think of including from underneath and now always put it in thru the top. we don't have a hoist just a jack and engine hoist
but engine with box attached is a pain too, all we did was bend the radiator cross member. wrxhoon tells me it can be done though :D
Through the top I put them in seperately its easyer but you need experiance getting gearbox in but I can do it in about 2hrs this way (only bolted in not hooked up) if you have a hoist drop the subframe. undo the hicas crap lines etc undo coupling from steering col-rack, remove you waistegate actuators, put motor and box onto crossmember bolt up mounts,drive shaft/axles, use 2 gearbox lifts 1 under crossmember 1 under gearbox raise up slowly bolt up. I looked at doing it from top box attached and it look like a world of hurt to me. But if you try it let us know how you go. if you need more advice pm me.
I can only speak for a 33 GTR but you can get the engine and box in together going over the top.
You need to make sure you have a chain block close coupled (don't just try and use the engine lifter) and fit a come-along or similar with a soft sling around the gearbox to allow you to tilt it as required.
It is definitely not a one man job but can be done with some help (mine went in and out about 4 times making sure the custom top pipes fitted).
Cheers
I have alwys done it:
Box from under the car.. attach cross member..
Put engine cross member, steering rack, engine mounts and then drop engine in from the top..
Sometimes you will need to wobble a few things around (depending on whether you still have AC compressor and power steering pump still attatched).. its easier still if you remove all that and attach after the engine has been dropped in
When your finished come up to sydney and do mine too :P
i'm thinking of dropping out the bottom. lifting shell up and draging out box and engine on a trolley.
i've already undone all the looms etc, just waiting on an engine crane to get it done.
i might try take the plenum off too as it looks like i'm going to hit the hicas shit. or move that out of the way whatever is easier
yer i would if i loved putting motors in but unfortunately i hate it, im not looking forward to it
i almost ed considered paying a workshop to do it
bloody engines in & out! it's a pain in the ass , ain it?? :ninja:
something most rb owners experience hehe
i think it's easy, i just normally leave it to Mark!! actually he tells me to f##k off as i just get in the way.
mind you it''s so much harder on a road car , generally!
true, no aircon and no hicas really helps. we did it in 3 hours 2 weeks ago, + 2 more hours to strip the motor to see how much damage we had done. going back in this weekend hopefully but that takes longer (no point rushing that and finding a coolant hose under the rear of the plenum is wrong)
As long as you can lift it high enough its easier from the top and as one unit ( engine/box) . the car has to be off the ground on stands so the whole unit can fit, its a very long unit . I never remove the steering rack, the air con compreesor can be tied to the rail and the m6 bolt that holds the power steering line on the drivers side has to b e undone. Careful not to bent the cluch lines with the plenum and drop it in nice and slow while someone is watching as it is a very tight fit.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
