hey guys im about to put my motor back into my r32 gtr,
i took the box and motor out together but i have to remove the steering rack to get it out,
is their a way to put them back into gether without taking the steering rack off??
iv heard if people putting the motor and box from underneath the car, im not exactly sure on how to do this.
thx guys
https://www.sau.com.au/forums/topic/208557-rb26-removal-with-box-attatched/
to put it in form underneath remove the whole subframe then put the motor and box onto it (do up engine mounts etc). they lower car back onto subframe, bolt subframe back into chasis and voila you are done
well we've tried every way we can think of including from underneath and now always put it in thru the top. we don't have a hoist just a jack and engine hoist
but engine with box attached is a pain too, all we did was bend the radiator cross member. wrxhoon tells me it can be done though :D
Through the top I put them in seperately its easyer but you need experiance getting gearbox in but I can do it in about 2hrs this way (only bolted in not hooked up) if you have a hoist drop the subframe. undo the hicas crap lines etc undo coupling from steering col-rack, remove you waistegate actuators, put motor and box onto crossmember bolt up mounts,drive shaft/axles, use 2 gearbox lifts 1 under crossmember 1 under gearbox raise up slowly bolt up. I looked at doing it from top box attached and it look like a world of hurt to me. But if you try it let us know how you go. if you need more advice pm me.
I can only speak for a 33 GTR but you can get the engine and box in together going over the top.
You need to make sure you have a chain block close coupled (don't just try and use the engine lifter) and fit a come-along or similar with a soft sling around the gearbox to allow you to tilt it as required.
It is definitely not a one man job but can be done with some help (mine went in and out about 4 times making sure the custom top pipes fitted).
Cheers
I have alwys done it:
Box from under the car.. attach cross member..
Put engine cross member, steering rack, engine mounts and then drop engine in from the top..
Sometimes you will need to wobble a few things around (depending on whether you still have AC compressor and power steering pump still attatched).. its easier still if you remove all that and attach after the engine has been dropped in
When your finished come up to sydney and do mine too :P
i'm thinking of dropping out the bottom. lifting shell up and draging out box and engine on a trolley.
i've already undone all the looms etc, just waiting on an engine crane to get it done.
i might try take the plenum off too as it looks like i'm going to hit the hicas shit. or move that out of the way whatever is easier
yer i would if i loved putting motors in but unfortunately i hate it, im not looking forward to it
i almost ed considered paying a workshop to do it
bloody engines in & out! it's a pain in the ass , ain it?? :ninja:
something most rb owners experience hehe
i think it's easy, i just normally leave it to Mark!! actually he tells me to f##k off as i just get in the way.
mind you it''s so much harder on a road car , generally!
true, no aircon and no hicas really helps. we did it in 3 hours 2 weeks ago, + 2 more hours to strip the motor to see how much damage we had done. going back in this weekend hopefully but that takes longer (no point rushing that and finding a coolant hose under the rear of the plenum is wrong)
As long as you can lift it high enough its easier from the top and as one unit ( engine/box) . the car has to be off the ground on stands so the whole unit can fit, its a very long unit . I never remove the steering rack, the air con compreesor can be tied to the rail and the m6 bolt that holds the power steering line on the drivers side has to b e undone. Careful not to bent the cluch lines with the plenum and drop it in nice and slow while someone is watching as it is a very tight fit.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
