Car Camera Mounts
Downforce
 Share
  • 2 months later...
  • Replies 70
I got the V.I.O POV.1 I love it it's rather expensive much more then the go pro, but I saw someone with it snowboarding on their helmet...Lets just Say I'm happy I stuck with my decision, I love it quality is awesome it's tiny and it's very versatile
I saw the Go Pro Hero in issue 72 of AutoSalon... ...Think this might be the one I get... ...It seems to also be the only unit in the market that is Mac compatible...
Just a few things keeping me back... ...It says it can only have 2Gb SD cards... ...I've got a few 8Gb SD cards lying around since I changed to a Sony "happy snapper" and had to invest in new cards... ...It seems to only run off batteries... ...I'd like to see a lighter plug power version... ...No "Shock Record" with leading buffer... ...If you're out in the street and happen to be in an accident it would be great if it could start recording with a few minutes pre-recorded before the accident...
There was a duel camera setup (outside and inside the car) a few issues ago in AutoSalon that had the features that I want... ...However it isn't Mac compatible... ...So no go for me...
If the little Hero could take bigger cards and record longer with bigger cards... ...then I would get it...
  • 1 month later...
I think they have a newer model which can read the larger SD cards now, something they didn't tell me when they sold me my Hero off the shelf... probably getting rid of old stock and it was more expensive than if I bought it from Lucas. Oh well.
Picture quality is 'okay' for the price, but I wasn't happy with the sound or the vibration (which I fixed by wrapping gaffa tape around it, I know this isn't hard to do, but another process all the same).
Look closely at the picture (when all is still) and you will see a heat like warp in the picture, sometimes its much worse and I think its electrical interference
  • 1 month later...
  • 1 month later...
Instead of making a new thread... ...I'm going to Bump this one...
I got me a Go Pro Hero Wide MotorSport kit... ...I ordered it from the U.S. and it arrived yesterday... ...It will be coming out on the next cruise for sure...
  • 1 year later...
I use a VIO POV helmet camera which came with a mount which holds the tiny camera on with really strong magnets. Quality is ok. Here is a pic of it on my roof.
Edited by phoenix88
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
