I have a Pioneer headunit - DEH-P9650MP. It has the dual faces, one that flips down to reveal the other.
For some reason it has stopped opening to reveal the 2nd face when I press the OPEN button. It also means that it wont eject the CD I have in there because to eject it also needs to open both screens. I stupidly hit the reset button to try and fix it, and it caused me to loose the subs because the controls for the subs are on the 2nd face which I cannot access.
Worst case I am going to just go out and buy another headunit, but I would like to at least get my CD out. Does anyone know if this model headunit has a "CD eject" button behind the faceplate etc like some have?
Also in regards to getting another headunit, I need to buy another Pioneer headunit because I have one of those Pioneer ipod control boxes for it. What sort of headunit feature do I need to make sure I get so that it will be compatible? There is one in the WOW catalogue atm that says it has Direct Ipod Control, which I am thinking is what I need to be able to control the iPod through the headunit, is this correct?
Any help for both of the above problems is much appreciated.
-Yvonne
https://www.sau.com.au/forums/topic/208622-headunit-help-mine-broke/
ribbon in the face is broke.common problem with them - $150 or so to fix it.
point me to the WOW one (via the pioneer site.) and I'll tell you if the box you have works with it. if it has IB in the model then it has the ipod lead in the box already and should be an in/out job with no changes to wiring.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
